Question about Technics Audio Players & Recorders
Technics receiver "overload"
  • 2,098 Answers
Hi Donna,
Overload indicated of excessive load to the power supply due to shorts. It will not power up(normal operation) unless the shorted parts isolated. The most common caused of this fault was came from the shorted output IC/transistor. These parts are mounted in the heat sink. You must pull-out these parts from the board and then turn on the unit. It will back to operation again because the power supply will not go to overload but will not produce sound because the Output IC was disable(not in the board).
If you don't have necessary tools and test instrument and can't troubleshoot the symptom yourself, I would advice you to look for a qualified technician to isolate the problem.
But first perform this :
Pull-out all inputs and cable in the unit. Turn it on, if "overload" still there, try the above solution. Let me know if the symptom does not show up.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 02, 2011
Technics sa-dx1050 overload
if any one of the channels was shorted out, even momentarily, that channel's output transistors would likely be blown causing it to stay in protection mode. (or overload as you put it). Time to visit the repair shop.
Jul 23, 2012 | Technics SA-DX1050 Receiver
On switching my technics sa-dx750 it says switching off overload
The question is what is causing the overload? The power supply or the output devices on the heat sink?
If you have accidently shorted a speaker wire, then the answer will be output devices, otherwise it could be anything in the power section. You may find a burnt or damged device with either of the causes.
Mar 08, 2010 | Technics SA-DX750 Receiver
Overload on sagx550 technics
Disconnect all speakers at the receiver then turn it back on. If it still goes into "overload" you need to have the unit serviced. If it stays on, post a comment and I can walk you thru troubleshooting your system.
Dec 22, 2009 | Technics SA-DX750 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
I have a technics sug91 amp the over load light comes on what can i do to remove it
you cant remove the overload light. it does that as a safty so you dont burn up the amp when its not being used properly. do u have a capacitor? are the speakers ohms and watts the same as the amp?
Oct 18, 2009 | Technics SA-AX540 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
158 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
