Question about Refrigerators
Our GE refrigerator is not cooling on the refrigerator side. The freezer is ice cold, the fan is running and I have disasembled the ice maker and put it back on to make sure there was no blockage. I also removed the cover inside of the refrigerator and the small opening between the freezer and the refrigerator is open but no airflow to speak about. I have tried unplugging and reseting the digital thermostat but again it is an airflow issue into the refrig. I have also cleaned out the bottom and the back panel of all dust and debris.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
Top shelf of freezer and ice maker not cold and top shelf of fridge not cold. everything else on bottom shelves is frozen and cold .GE model GSS22JEMA
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 17, 2010 | GE GSS22JEM Side by Side Refrigerator
Refrigerator and freezer are both cool, not cold.
Pull refrigerator away from wall unplug remove lower cover and feel top of compressor. If too hot to keep hand there leave unplugged until start components, compresser windings and condenser fan can be checked. Let me know what you find and I can assist you, Thanks, Sea Breeze
Feb 20, 2010 | GE GSH22JFT Side by Side Refrigerator
Fridge not getting cold, ice maker not making ice
It sounds like it is doing some cooling. Check to see if your evaporator fan is running and there is not ice buildup on your evaporator (indicating a defrost issue, common on ge refrigerators, usually heater goes bad), you would either see ice on the back wall of freezer or if you take off the back wall you will see lots of frost. Also check if your condensor fan is running and clean the condensor. The compressor is running since it is getting down to 27 but if it is not being cooled it will shut down. Another common problem on the ge refrigerator is the main board contacts going bad and not running the compressor. If your compressor is running the whole time and none of the other conditions exist it sounds like you have a leak or restriction in the refrigerant or sealed system.
Dec 13, 2009 | GE Profile PSC25PSWSS Stainless Steel...
Ge side by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
gfhjsf
Jun 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Refrigerator/Freezer not cooling
Loss of coldness is common with compressor related problems....relay and overload(simple fix), loss/leak of refridgerant(need a cert. tech). need to check the compressor and see if its running....do this by pulling the unit out and removing the back panel, place your hand on the compressor and see if it feels like its running....if not probably just a relay, if it is running, could be a more serious problem dealing with sealed system.
Jun 10, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Fan in freezer under ice maker won't stop running.
Hi yes the fan blade could be hitting the shield or ice, remove the fan cover & check
Dec 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Aug 28, 2008 | GE GSS20IEP Side by Side Refrigerator
Fan is Running
Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
Nov 14, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
