Question about Whirlpool Dryers
Hello there ,I have a model lgn2000pw1 gas dryer it has quit heating. I have looked at the exhaust hose it is clear. the glowbar will come on for about 7 seconds and go off it will repeat this every 30 seconds or so ,but still no flame
  • Whirlpool Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Apr 02, 2011
HOW CAN A DRYER IGNITE A FLAME AT FIRST FOR TEN MINS THEN WHEN THE DRYER WANTS TO HEAT UP AGAIN I SEE A GLOW BUT NO FLAME COMES THE SECOND TIME SHOULD I REPLACE THE THERMAL FUSE
No you should replace the coils. 3a3915a.jpgWhy? You know you are getting power to the gas assembly so that means the fuse and control are functioning. The igniter glows so that is good. The Flame detect is fine because it shuts down the glowbar when it heats up. So those pesky coils get hot and quit. They eventually cool back down and work a little more, very aggervating to diagnose but easy to fix.2b3709e.jpgNote you do not have to remove the gas assembly to replace these coils.
Apr 23, 2010 | Whirlpool Dryers
The dryer puts off a chemical smell on the clothes-gas dryer
If it smells like gas on your clothes, your exhaust vent is probably being restricted, causing the exhaust to back up into the dryer cavity. Remove exhaust hose, make sure it is clear all the way to where it exits your home.( sometimes birds build nests in the outlet vent) Look into vent where hose attatches to dryer, and make sure it is clear also. If you smell gas when moving the dryer, there should be a shutoff valve near the wall, close it. DO NOT THE DRYER ! ! Call someone qualified to make the repair.
Feb 08, 2010 | Maytag Dryers
Dryer will not heat up...all vents are clear
if the motor turns,then it could be the glowbar/ignitor,the cycling switch,the flame sensor,the gas valve coils,a thermal fuse,temp switch,hi-limit thermostat,or the electronic dryness control
Oct 27, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Gas dryer does not completely dry
Replace the glowbar ignitor and also the gas valve coils.
Aug 18, 2009 | Kenmore Dryers
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
Hello, My gas dryer FRIGIDAIRE with model
check exhaust ducts and inside bad of machine for lint blockage over heat shuts down heat if not igniter or gas valve failure likely
Jul 06, 2009 | Dryers
Gas smell, oven not heating up
You gas oven uses a glowbar to both regulate and ignite the gas entering the oven. If this glowbar is faulty, it might let some gas into the oven but it is not hot enough to ignite the gas. That is why you are smelling gas. I would suggest to start by replacing the glowbar (and if this is not the solution, simply return the part for a refund). The part you are looking for can be found online here: http://www.partselect.com/PartDetail.aspx?Inventory=470129&SourceCode=1
It is quite easy to replace. Simply remove the free-standing pan on the bottom of the oven, unscrew the existing glowbar, remove the back cover from the stove and trace the two wires that belong to the glowbar and unplug them. Thread the two wires from the new glowbar through the opening and reconnect to the plugs at the back of the stove. Screw in the new glowbar and test. Most oven ignition problems are caused by faulty glowbard. Good luck.
Jun 27, 2009 | Tappan TGF657 Gas Kitchen Range
GE SPECTRA JGBP35 Gas oven
Solved a similar issue. Sounds like your glowbar igniter is shot and needs to be replaced. While the glowbar is glowing, it is not heating up sufficiently to release gas into the oven. The heat you feel in the oven is actually from the glowbar and not from ignited gas. Replace the glowbard. Here is what I recommended to someone else:
"Would be helpful to know brand and model. However, most gas ovens use a glowbar mechanism that regulates the amount of gas released into the oven. The glowbar also ignites the gas (and usually stays on all the time the oven is on). Often, the glowbar fails to heat up sufficiently and, as a result, doesn't allow the oven to release sufficient gas. If this happens, you may also smell small amounts of gas in the kitchen. The glowbar is hot enough to ignite the limited amount of gas being released into the oven. This is probably why the oven heats up but heats up very slowly. It's also possible that the heat being experienced in the oven is being generated from the glowbar itself without any gas being ignited. If this is the case however, it is unlikely that your oven to get very hot at all.
The way to test to see if they glowbar is failing is to test the amperage traveling to the glowbar when the oven is on. You can do this using a "clamp on meter" (purchased at any Home Depot or Lowes). Depending on the particular kind of glowbar you have, it should read above a certain amperage (in my case the reading was 2.7 amps and it should have been between 3.2 and 3.7 amps). I ordered a new glowbar from www.appliancepartspro.com and installed it myself (very easy). It fixed the problem. Here is a link that explains it pretty well (http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow). Hope this helps."
Jun 24, 2009 | GE Spectra JGBP35 Gas Kitchen Range
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Jun 22, 2009 | Maytag Dryers
Open Questions:
Dryers Logo
127 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
