Question about Ludwig L315fp Accent Custom Single Bass Drum Pedal
My ludwig L315FP bass drum pedal keeps bouncing and i have loosened the spring all of the way. I still cannot get it from multi hitting the bass drum. Help?
  • Ludwig Master
  • 5,603 Answers
Go to YouTube and search for "Bass pedal" There are many videos. Select and view ones on "setup" and also view "technique". These will solve the problems you are having.
Posted on Apr 02, 2011
Im having problems attaching my Gibraltar Intruder Direct-Drive Double Bass Drum Pedal  to the bass drum
Does it hit the drumhead?
I guess you need to read the instruction manual, because double pedals usually have special way of attaching and tightening mechanism because it's larger.
Mar 03, 2014 | Gibraltar Intruder Direct Drive Double...
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
I just bought this kit and I'm watching the DVD Drumset 101 that came with it and it starts by saying to "lower" the bass drum spikes. They aren't even attached, I don't even know...
The "spikes" are the legs near the backside of the drum that keep it from rotating... Some actually have spikes that go into sockets and dig into the floor under the drum. The photo shows the legs. The drum pedal may have spikes and or a clip/clamp that grabs the nearside of the bass rim to keep the pedal from pushing the drum away.
Sep 07, 2011 | Pacific International Pacific Drums by DW...
I am using the stock pedal that I got with my set 6 years ago. I know it's time for an upgrade but really, I can't afford it. First off, the piece that connects the chain to the main bar (sorry for...
It is NOT clear how the parts are loose. If they are threaded things, go to the hardware store and get a product called "Threadlocker" or "Loctite" and use as directed. Clean the parts with alcohol solvent before applying the Threadlocker. If threads are too far gone, then use JB Weld which is a filled epoxy to fill in worn part.
May 15, 2011 | Ludwig L415FPR 400 Series Single Bass Drum...
Hi, I have a Ludwig Classic Maple drum comprising: Bd 16x24, Sr 5x14 , Tt 7x10, Tt 8x12 , Ft 14x14 , Ft 16x16 . I am very happy with the sound of this drum, very powerful, resonant, and easy tuning, I have...
Here I've listed valuable reference information on bass drum tuning and achieving the lowest pitch possible. Some things are trial and error but once you fully familiarize yourself with drum tuning you should be able to achieve the sound you want. Hope this helps.
Kick Drum Tuninghttp://home.earthlink.net/~prof.sound/id6.html
Bass Drum Tuning Lesson http://www.drummerconnection.com/drumlessons/youtube/46667-bob-gatzen-bass-drum-tuning-lesson
Apr 05, 2011 | Ludwig Classic Maple Power Drum Set Shell...
My Roland TD-6 Bass drum pedal spring has come off the Pedal. How do I put it baxck on?
There should be a nut and a cylindrical tightener at the bottom of the spring. If you loosen these, you should be able to pull the spring up and get the ring back onto the post. Then just tighten the nuts back down to where the tension feels right.
V-Drums don't all come with the same kick pedal--in fact they are often sold seperately--but this should be enough to help you with most basic kick pedal designs.
let me know if this doesn't make sense and tell me anything else you can about the pedal itself and I'll find a picture so I know what you have. This should work though. Good luck!
Mar 04, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
My Yamaha electronic bass pedel is not working. If I unplug the connection to the computer and plug it back in I will hear only 1 sound of the base drum. Could the base pedel round pad which is hit by the...
There is a piezo sensor behind the pad typically. This can be dislodged or damaged. FIRST check your cables and try plugging the bass into another inout and see if it will trigger that sound. If not, you will need to repair the bass pedal.
SOME pedals have a sensitivity control which is a tiny pot accessable through a hole... this too is easily damaged if wrong type screwdriver is used to adjust it.
be sure and check for a broken cable, especially near the ends.
Sep 22, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Dd 55 drum machine bass pedal has stopped working any ideas please.
MOST of these use a piezo disc pickup.
Other than replacement, first try to open the case and see if the disc has been knocked loose.
DO verify that the other one with the set will trigger the bass when plugged into the bass input... they are compatible triggering wise.
Frankly, these "pedals" are really hokey... could prpbably use one from a fancier drum set with a true pedal.
Oct 31, 2009 | Yamaha Music
The Bass Drum Pedal of our Yamaha DTXplorer electronic drum kit has come to pieces. There are springs and washers everywhere and I don't know how to fix it. The instruction manual doesn't tell me. If you...
Go to one of the suppliers. Most of them will have photos of the bass pedal assembly and if you can enlarge the photo, you should be able to figure how to assemble it.
Expect to find washers on shafts between things that rub.
The owners manual at:
http://yamahadtxplorer.com/yamaha-dtxplorer-owners-manual/
Check on page 9 for example. While the photo isn't the greatest you can see where the spring is.
Sep 11, 2009 | Yamaha Music
For Sale Brand Korg OASYS 88 88-Key Workstation ????2100.00 EUR
If you scroll to the bottom of the page and click on Advertisers the site can help you.
Aug 05, 2009 | Music
Ludwig L315fp Accent Custom Single Bass Drum Pedal Logo
203 people viewed this question
Top Ludwig Music Experts
Vito Vacirca Jr.
Are you a Ludwig Music Expert? Answer questions, earn points and help others
