Question about LG 24 in. LDF 7811 Built-in Dishwasher
Hi there, We have a LD-14aw2 LG dishwasher. It doesn't clean the dishes, doesn't matter how i pack it. I'm not sure if it is suppose to dry as well, as we bought the house with it in, but the dishes are very wet when it's finished. Thanks Susan
  • LG Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Apr 02, 2011
LG dishwasher LD-14AW2 starts up & tries to drain for about 2 mins & then the alarm comes on. The wash, rinse & dry lights are flashing. The hose is raised and not blocked because we can blow...
Hi Jeff - am not too savvy with LG - am a Electrolux/Miele serviceman is it possible to gain access to the drain pump from inside the unit? I think it does sound like there is a restriction somewhere perhaps the pumps not running freely.
To check you pour water inside , take the drain hose , operate machine to see how good the flow of the drain is, rule of thumb if you cover the outlet no flow then the problem.
hope this is a start..
Jun 17, 2011 | LG 24 in. LD-12BW5 Free-standing...
I have a LG LD-14AW2 dish washer. it starts and then displays "HE". Is it the heater unit?
Hi glen bundese,
Yes it is the heater unit...
HE means Heating Error - The Element needs to be replaced - Or the Thermistor on it, though if the thermistor was faulty it would give a TE error.
Both parts come as a unit (Usually). I would refer you to a qualified L.G technician in your area
- Replace the element unit, and things would be OK.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful, please rate it.
Jun 11, 2011 | LG Dishwashers
Where can I access / buy a lg dishwasher ld-14aw2 repair manual
go to google put in the manual you want and 5 sites will come up offering them at several prices
Feb 28, 2011 | LG Dishwashers
I hav a lg Dishwasher model # LD-14AW2 the problem
broken door cord. remove side panels and relace. this is a cheap and easy fit. make sure you replace both sides at the same time, you will most likely find it is only one side broken at this stage, but the cords do not last very long.<!-- from fixya rte -->
Jul 07, 2010 | Dishwashers
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
Dishes don't get clean and don't dry
Hi reesbag
I'm Harvey the Master Plumber.
You're question is why the dishes don't get clean and it is not drying at all even though jetdry is full?
To begin with "jetdry" does not dry your dishes, It is a product that you can choose to use if you have a problem with spots on the clean dishes when the dishwasher is done.
Your problem is serious! If still under warranty then you're covered. If not and it has some years on it, it doesn't pay to throw good money after bad. If it came with the house it will be better in the long run to replace it. If you choose to repair, this problem doesn't lend itself to home handyman and it is likely in this case that after paying a repairman to come out you'll end up buying new anyway.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
May 11, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Model LD1403W1
Are you using a rinse aid like Jet Dry??  All dishwasher manufacturers now require that you use rinse aid for drying dishes at the end of the cycle.
Dec 29, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LDF 7811 Built-in Dishwasher Logo
201 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
