Question about Sony Playstation 3 (PS3) Console
My kids ps3 is frozen; sometimes it shows a introductory screen that basically scrolls and sometimes it don't; the power light is green and only goes red when the system is turned off by pressing the on/off button. Any idea what I can do to fix this?
    Genius:
  • 1,622 Answers
How to fix your PS3 when it's frozen at start up
things you'll need:
* PS3
* TV
* Game Controller
* USB cord
Instructions
The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
Put your PS3 in Standby Mode.
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
Time to enter Safe Mode.
Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
Connect controller to PS3 screen.
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
Safe Mode options screen.
Select option number 3, (Restore File System). Then select yes to perform step.
"The hard disk's file system is corrupt and will be restored."
First press the PS button to turn the controller back on. Then press the x button and it will restore, it will then restart and your problem is fixed!
Posted on Apr 02, 2011
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Apr 02, 2011
    Top multimedia features are on the console of PS3 and it is also connected with PlayStation Portable. While having all the high features, PS3 is not protected from occasional freezes and one knows that. It is the most irritating time when one is enjoying the best of the gaming time when everything suddenly comes to a halt. It is rare that PS3 will freeze but they do occur sometimes and are caused by scratched console disk or overheating.
    1. Overheating: When the console is kept in a stuffed room where there is not ample breathing space, then it will get overheated and too much heat on the PS3 will cause a meltdown. It can easily be remedied when the console is placed all by itself and no other electronic machine is nearby.
    2. Scratches: Scratches on the disk that can cause looping inside and this usually happens at millisecond speed. The console is not actually frozen in this case. Its the time lag that gets continuously repeated at certain times. The freezing of PS3 is generally not too serious. In case of worst freezing, the console has to be taken to the Sony store from where it was brought. The fact is that the owner can only do some basic trouble-shooting for fixing the problem.
    If a PS3 freezes, it has to be kept away from other electronic machines at home. Its power button has to be pushed until a beep is heard. The loose cables have to be checked and they can be pulled and plugged back in. The hard drive has to be aired out for a while and placed back in the console after a considerable time.
    If this does not help then the repair guide can be consulted to try fixing the PlayStation 3. It is completely detailed and illustrated.
    Briefly, this is how it is done:
    - The console has to be taken apart carefully
    - The CPU and GPU of the console have to be checked. A white can be seen that may be cracked and unevenly spread, it will need a cleaning.
    - The console's GPU and CPU has to be cleaned using a dry paper, if a sand paper is to be used then an extremely rough one should not be used.
    - The flat surface has to be cleaned and if still there is a need, Arctic Silver 5 Compound can be purchased and used. It has to be applied evenly and thinly on both surfaces.
    - The surface which distributed thinly makes sure that every single gap is covered.
    - The heat sink cap can be finally put back on.
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
When i turn on my ps3 the light on the front goes green white red
Send it in for service at a Sony playstation service center.
It is possible you have a hard drive problem, but you will basically need to buy a hard drive and install it to find out.
Apr 21, 2010 | Sony Playstation 3 (PS3) Console
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
My 60GB PS3 is having trouble starting up. Some red and green spots show up and then freezes. It took some pictures when it freezes. Any help? Is my PS3 going to need service? Is it just a HDD issue? Many...
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns on with green light an doesn't show users screen blank
Your tv screen has problems with the video mode
that has setted up on your ps3, hold the power button till hear two beeps, this will reset the video mode of the ps3, and leavse you at a screen to set up the video mode of the ps3.
Succes.
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Turn power on and the light goes from green to blinking red.
you have the yellow light of death.. go to youtube and search for that and there are some self help videos.. basically u have to take the whole machine apart and reheat the cpu and gpu chips
Aug 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
43 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
