Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
I have a side-by-side Whirlpool fridge. Has begun to make loud machine type noise (like a lawnmower or weed eater) intermittently. Opening the freezer/fridge door and depressing the light swith does nothing - sound continues. ..Only cure is to unplug it, wait a few seconds to a minute or so, and replug. That stops the noise . When the noise is happening, I canot tell if the fan blades are on, but when it is unplugged, the blades look fine to me. After replugging, I could then tell that the fan blades are moving smoothly.What could the problem be?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Posted on Apr 02, 2011
When I turn my weed eater on it makes a loud noise what could the problem be?
will assume electric
fixable
would say bearing at the cutter head dry or worn out
when you turn the head to edger the load on that bearing is different
if noise is up in the motor same thing .. bearings
Oct 13, 2016 | Garden
When it is lcooling it has now begun tomake loud vibrations.
it is most likely from the frame of the fridge that the compressor is mounted on vibrating on the floor
I use two door wedges ( available from the hardware shop and I push one under either side a bit to get clearance from the floor
the noise stopped but the problem is that there is nothing available on the market to replace the wedges
rubber buttons under the plate worked but to stop the noise they tend to make the fridge unstable when opening the door or the front of the fridge has to be adjusted up so that the door self closes
try that and if it works the you are on the right rack
if not you may have to get the compressor rubber mounts replaced as they may have collapsed and allow the compressor to hit on the plate
Oct 14, 2015 | Maytag MSD2454G Side by Side Refrigerator
Weed eater one friction disc problem
HOW REPEAR THE FICTION HOB WEED EATER TRACTORS
Aug 22, 2012 | Garden
What is the purpose of having two different size fuel lines in the fuel tank on a weed eater trimmer ?
Weed eaters have a diaphram operated carburetor instead of the float operated ones on a lawnmower. The bigger one is the fuel to the carburetor and the little one is the return to the tank from the carburetor.
Jul 27, 2011 | Garden
I have weedeater but my fuel line ic corroded what type of line do I need to order
There is special silicone piping made for weed eaters and it is available at all lawnmower spares suppliers. Do not use conventional plastic tubing, it goes hard in fuel and will not follow the fuel as the machine is manipulated.
Jun 08, 2011 | Vacuums
Type of oil needed for weed eater sq 4.5 lawnmower
2 cycle oil ... available at your auto parts store or where garden equipment is sold. Normally the mix is 50 to 1. Check your owners manual to be sure.
Apr 26, 2011 | Garden
Looking for a manual for an electrolux lawnmower, also says poulan weed eater. Model # 386191. It does not seem to get enough gasoline.
You can try draining the carb and cleaning the main jet first?
If the carb is a bowl type also check the float to see if enough gas is flowing when the float hangs free. The carb should stop flowing then the float is lifted up and is sitting parallel to the carb body.
If you dont have a float type carb you can remove the carb body and check for dirt in the pickup tube as well as the main jet.
Here is a link to the poulan weed eater website:
http://www.mccullochpower.com/node6476.aspx
Aug 06, 2010 | Poulan Garden
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dont know about the noise prob. but I can help with the over heating cabinet. Your condensing coil is dirty and needs cleaned. it is located under your refrigerator or behind the back panel. You should use a brush and vac. it out. Air must travel through the tubing freely in order to cool properly. It should be easy to find following the tubes coming out of your compressor.
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
206 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
