Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Our freezer is working fine but the air flow to the refrigerator is not flowing in. It has digital controls and I have taken the cover off off the inflow valve/blocker and it is open, yet no airflow into the refrigerator. The fan is running in the freezer side but not as strong as it has in the past.
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
Refrigerator not cooling; freezer fine
I don't know which model refrigerator you have but nearly all refrigerators cool the refrigerator section by passing cold air from the freezer section. Often the air passage will ice up so that the cold air can't get through. A thermostat controls the air flow,
That should be enough information to help you find the problem. You may have to remove some inner covers to find the problem.
Aug 03, 2014 | Admiral Refrigerators
FRT221RSH refrigerator warm...freezer cold...some frost on back of freezer wall, i popped off the small cover on the inside back wall of the freezer and the fan there is running...i vacuumed a little dust...
If you remove the entire back panel of the freezer section there is a evaporator (aluminum grill looks like a car radiator, contains r-134a, do not puncture or unit is ruined) Some frost on back freezer wall, means probably this entire grill is encased in frost, not allowing any air flow, which is how the entire refrigerator section is cooled, by air flow) The frost build up has to be removed,(got a hair dryer) you can unplug it for a couple of hours with the door open, overnight is better,this would fix the problem for a couple of weeks....Your automatic defrost is not working, there are three parts- the timer or control board, a heating element, and a bi-metal thermostat(often the problem)
You popped off the cover for the ice maker, you need to defrost the whole freezer section behind the back panel. Freezer cold means your compressor and freon are fine, you have a defrost problem with ice build up restricting air flow. A normal automatic defrost runs every 8 hours, three times a day, rule of thumb.....Sounds like you have a couple of weeks built up...........
hope this helps
Feb 23, 2011 | Refrigerators
My refrigerator is not working, but my freezer is
Usually there is a air flow problem from it not defrosting(all the evaporator coils are frosted up with moisture preventing air flow-defrost problem ) or the fan motor is not turning in the back of the freezer section above the evaporator....
All of the cooling in the top or refrigerator section is done by air flow circulating across the coils in the freezer to get temps down to 38 degrees or so. You have to listen for the fan running in the freezer section, feel for air at the top back of the refrigerator(the damper control) Sometimes a bi-metal thermostat in the defrost circuit is also used in series with the evaporator fan motor, if it is open the fan will not run........(this I have seen) Also check the vents for the return air to the freezer(behind the crispers are not covered accidentally) Hope this helps........
Jan 10, 2011 | Maytag MFD2560HES Bottom Freezer French...
The freezer is working fine and I hear the fan in the freezer working when I open the door, however the refrigerator is not getting enough cold air into it. I place my hand under the vent where the air is...
The "control" on the freezer section is simply a mechanical air valve and controls how much freezer air actually goes into the refrigerator section. No electronics here at all.
So, IF not enough air is coming into the refrigerator, LOWER the setting on the Freezer Control .... mine has letters A B C D E try "B" and see what happens. You should feel an increased air flow at the air vent.
You may have to INCREASE the "Fresh Food Control" control to a HIGHER setting to compinsate for directing more air out out the freezer ... try 6, 7, or 8. This IS an electronic control and controls the ENTIRE refigerator's cold generation.
If this don't work, there is some other problem, like the defrost heater is out and there is lots of ice behind the back freezer wall stopping or reducing the air flow.
Aug 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer has ice in it
Sounds like your refrigerator is not defrosting or there is some other air flow problem with your unit Melanie. Could be a problem with either your defrost heater, defrost bi metal thermostat, defrost control, evaporator fan, air damper, air damper control, or some other air flow issue. I would recommend you have a qualified refrigerator repair service inspect and diagnose your unit.
Apr 07, 2010 | Maytag 18.6 Cu. Ft. Bottom-Mount...
Freezer is working fine but no cold air getting to the upper area
If freezer is cold then you are not getting air flow to the frig side. Check your air flow setting It is the one next to the thermostat. If in doubt ,just set both controls to the middle setting and check in an hour or so.
Jul 23, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Fridge gets no air flow, freezer works fine
Air from freezer could also be restricted. Need you to find me the correct model number.
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • Thanks, Sea Breeze
Mar 24, 2009 | GE Profile Stainless Bottom-Freezer...
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Mar 04, 2008 | Kenmore 64823 Top Freezer Refrigerator
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
52 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
