Question about GE Dryers
To replace the belt on GE Dryer DISR473DG1WW, we will need to open the back of the cabinet, right? Is there a repair manual showing the process? Does this dryer ship with a spare belt inside?
    President:
  • 1,273 Answers
Hello, W/D here.
I'm not aware of any dryers shipping with a spare belt on board, but this may vary by region.
You are correct in that the back is removed to gain access to the belt. Disconnect the power first. If there isn't a spare in the cabinet (probably not), take the old belt with you to your local appliance parts supply house and get a replacement, or it may be ordered on-line. The belt number will be on the belt.
Here's a good website showing how your model is assembled. This site also has parts descriptions and prices; useful for comparison shopping. There is also usually a button-link to a free downloadable manual. Here 'tis: http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DISR473DG1WW/0432/0151200?pathTaken=&prst=0&shdMod=DISR473DG1WW
Another good site to check for parts is: http//www.appliancepartspros.com.
Armed with these items, replacing the belt will be child's play for you!
Best regards, (and please rate this solution), --W/D--
Posted on Apr 02, 2011
I have a maytag neptue dc dryer & I need to know how to replace the belt
open the cabinet:
http://www.partselect.com/dryer+maytag-atlantis-open-cabinet+repair.htm
route the belt:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
May 22, 2011 | Dryers
How do you gain access to rge belt drive to replace broken belt on the LEN2000LW dryer.
you will need to open the cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
then replace the belt:
hope the helped Tim
May 21, 2011 | Whirlpool LEN2000PW Dryer
Belt has borken
how to open a cabinet:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt diagrams:
Apr 15, 2011 | Dryers
I need to replace tumble dryer belt
how to open dryer:
belt diagram:
note Kenmore/Whirlpool are the same
Mar 19, 2011 | Dryers
My GE DSXH43EA2WW Dryer is making a squeaking sound when running. Tends to get less noisey as the dryer continues to run
Hello
You will need to replace the dryer belt and inspect the belt rollers while you have it apart. If you go to the web link below it explains how to take apart the dryer to replace the belt, it has additional links to pictures and diagrams within the instructions. The first link is for replacement parts with diagrams of the dryer. Here is that link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130504&diagram_id=21844825#d21844825
The next link is the Do It Yourself Article on replacing the dryer drum belt. while you have it apart remember clean the lint and dirt out of the cabinet interior. Here is the repair link:
http://www.applianceaid.com/ge-dryers.html#belt
Jan 14, 2011 | Dryers
How do i replace the belt
open dryer up: http://www.partselect.com/dryer+ge-open-cabinet+repair.htm
note the routing: http://www.applianceaid.com/images/belt-config.JPG
I would check eBay for a dryer belt as it took two days and $4.95 for my belt. Good Luck Tim
Nov 29, 2010 | General Electric DHDSR46EGWW Dryer
The belt on my dryer broke. How do I replace it
open a cabinet:
belt diagram:
Hope this helps, you may want to clean out all the lint inside the dryer since it is open. Tim
Nov 27, 2010 | Whirlpool ET8CHEXSQ Dryer
Maytag Dryer Repair
Easy fix.
Open the top cover by insrting a putty knife in the top right and left sides where the top meets the bottom cabinet.
Lay the top to the back.
Remove 2 screws on the right and left front inside corners of the cabinet.
Remove the door.
Replace the belt around the drum and motor pulley.
Re-assemble the dryer.
Mar 10, 2009 | Maytag PYE2300AY Electric Dryer
How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Feb 05, 2008 | Dryers
Dryers Logo
144 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
