Question about RTO Atwood Water Heater - 6 Gal LP
I have an atwood gas/elec elec igniton 6 gallon water heater. It lights up normal with a good flame but the valve turns off after about 5 sec. I have jumpered out the thermo cut-off, same prob, I have checked the alignment of the sensor and cleaned all contacts. I also did a resistance check on the sensor and it changes with heat. Any help is appreciated
  • RTO Master
  • 6,674 Answers
Have you checked for voltage each side of thermostat and ECO ? Make up a short jumper wire ( with 2 male spades) and put it between 2 female spades connected to each of them, (by-passing them) one at a time. (remove from therm, or eco, and use jumper instead) If it fixes it on one or the other, change it. Otherwise I'd try a new electrode/sensor assy, before changing igniter board. Be sure alignment is good for nice hot flame at tip of igniter/sensor assy.
Posted on Apr 02, 2011
I have a 6 gallon Atwood water heater, model GCH6-7E, DSI, heater lights off on gas when swithch is placed to on position. Heats water very hot , but when switch is put in off position, flame is reduced by...
Your on right track. When this happens and small flame still there, pull wire(s) off at gas valve, or test for voltage from ECO to gas valve. No voltage, then there should be no gas. Change gas valve.
Oct 20, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood gas waterheater with white rodgers gas valve pilot hard to light and not a big enough flame to touch the thermocouple
I think you need to reposition the thermocouple, or adjust the pilot gas pressure by adjusting the pilot screw make sure it is still the recommended gas pressure of the system... please contact a HVAC tech if this things did not work.
Aug 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
The electronic ignition on a gas water heater will not heat up and glow red to ignite the gas to heat the water atwood r/v water heater
You won't see any red glow until the burner ignites and burns for a while. Its only an ignitor and flame sensor, not a glow plug style.The ignitor has to provide spark for gas to ignite, then it also senses the flame and keeps gas flow coming. What exactly is happening when you turn it to on?
Jul 18, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I just replaced my gas valve thermostat on my 6 gallon Atwood water heater model G6A-7 and the pilot lights fine, but as soon as I turn up the gas, the flame almost engulfs the tank. There is even a flame...
There are a couple of things to check....
I am assuming that the gas is LP or Propane....
make sure that the gas valve is for the right gas and not natural gas...
Also, it is possible that the regulator that cuts the pressure from the tanks is bad and that maybe why the original gas valve failed....
If you have the correct gas valve installed, get a gauge and check the pressure of the gas right before the gas valve...it should be somewhere between 8 and 12 inches water column...
If the regulator is not working properly, check that the vent hole in the regulaor is not plugged by a mud wasp nets or something like that...
heatman101
Jul 16, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
On an atwood water heater, I have a small yellow flame at the main burner orifice, but nothing comes through the burner tube. The tube is clean and so is the orifice. The gas valve is new.
You need to have a manometer (pressure test) done on your system. If all that is new and clean, as stated, then you either have low pressure or a faulty/improper, gas control.How's the flames look on stove burners?
Jun 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
Water heater work fine on gas but not on elec
there is a big diffrence between a gas and an electric water heaters,, what you have on here is a 6 gallon water heater, it will take longer for electric to keep up hot water then it would for a gas water heater,,
Jul 28, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwwod 10 gal gas/elec water heater won't work on elec.
THE LIGHTED SWITCH SHOULD BE THE 12V ENERGY SOURCE TO ACTIVATE THE LP SIDE OF THE HEATER. THERE SHOULDN'T BE A LIGHTED SWITCH FOR THE 110 SIDE. THERE SHOULD BE A SWITCH OR A COMBINATION OF SWITCHES. ONE ON THE WALL LIKE A LIGHT SWITCH AND ONE MOUNTED BEHIND THE HEATER.
Jul 07, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
RTO Atwood Water Heater - 6 Gal LP Logo
52 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
