Question about Human Touch Ijoy 100 Robotic Massage Chair Camel
Some of the massage settings not working and moving slow up and down
Where can i find the fuse?
What Can Break in a Massage Chair? - Elite Massage Chairs
https://www.elitemassagechairs.com/what-can-break-in-a-massage-chair/
So believe it or not, the most common problems in a massage chair - about 90% of ...but it's not always easy depending on the design of the chair to find the fuse that ...This is the electric motor that moves the footrest up and down in a smooth ...
power outlets fuse location Electric Massaging Chairs ...
www.fixya.com > Forum > Tags > power outlets fuse location
Electric Massaging Chairs power outlets fuse location questions and answers. ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product ...Where can I purchase a plug in outlet chord (power chord) for the osim ...
electrical fuse blown Electric Massaging Chairs Questions ...
www.fixya.com > Forum > Tags > electrical fuse blown
Electric Massaging Chairs electrical fuse blown questions and answers. ... In short does anyone know where I can get a circuit board for this chair? ... I need to find the massaging mechanism unit for my ijoy 250 massage chair Product manual: ...
radio ht Electric Massaging Chairs Questions & Answers ...
www.fixya.com > Forum > Tags > radio ht
Electric Massaging Chairs radio ht questions and answers. Ask your radio ht electric massaging chair questions. Get free ... Do you know where I can find fuses?
Amazon.com: Electric Full Body Shiatsu Massage Chair ...
Dec 14, 2015 | Furniture
How to move osim ucomfort massage chair
Heyy..!!
I have used brookstone massage chair. In my point of view brookstone massage chair is the best. It offers foot massages that can give great therapeutic massage which helps to relax the joints and muscles. It is the best massage chair in comparison to others. I like this massage chair..!!!!
http://massagechair.me/
Feb 08, 2014 | Brookstone Massage Chairs: Certified...
Microprocessor massage chair error
Mine is doing the same thing. It was working and then I moved it by car to another house and now it's not working mine is a Feel Good ME-8511
Jan 08, 2012 | Kong King Usa D5000 Mercury Deluxe Massage...
The motor that moves up and down the back does not work.
That motor is located at the base of the backrest unit. It operates a lead screw drive that positions the kneading/tapping motors and rollers. The motor is controlled by the PCB unit that covers the length of the back of the massaging unit. Human Touch will not sell individual replacement parts. They will sell only the entire backrest assembly for $600 plus $60 shipping. It can be replaced without tools in less than five minutes.
Aug 28, 2011 | Human Touch HT 7450 Massage Chair
THE MODEL IS EP578.ROLLERS DONT MOVE BUT MOTOR IS FUNCTIONING.LIGHTS IN THE REMOTE ARE BLINKING ALL TOGETHER THEN THE MACHINE STOPS.
I found with my Panasonic EP578 that, if the lower photo sensor limit switch gets too dusty, the massage mechanism will travel downwards past the normal range of motion and the electronics will time out because the unit did not get a down limit sensor signal & reverse direction and proceed back to the upper limit switch in time. With the device unplugged, I simply removed the grommet screws and opened the fabric backing. Then I removed the units cover and Then blew out dusty photo sensors with compressed air. Then I swapped the red and green, 2-pin mag clutch coil connector plugs so that when I switched the unit on again I could make the unit travel back up to about, the scapular position. The reason that this is possible is that when you first start a normally working machine, the first thing that happens after the motor turns on, is that the motor clutch for the mechanism that provides the neck and vertebral massage balls, also energizes. I figured that I could get the voltage at that connector to energize the rolling clutch to get the unit back up again (as you can't move it by hand). Then I turned the unit off (while stile in cycle) and the swapped the mag-clutch coil connectors back to their original position. Re-starting the machine causes the moving massage mechanism to go through it's Power On Routine which realigns everything to it's 'Home' position and ready to run a fully functioning cycle. Remember to unplug the machine when working on it and keep all fingers, necktie, hair, jewelry from moving mechanism when it's moving to avoid damage to the machine and bodily harm to yourself!
P S here's a link to a service manual .pdf download for the Panasonic EP578:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwj_zpzD_NvQAhVpqFQKHb6EBbgQFggeMAA&url=http%3A%2F%2Fblog.lincomatic.com%2Fwp-content%2Fuploads%2F2013%2F01%2FEP578.pdf&usg=AFQjCNESCMv3PGtxbXCJfn-RHnEBwiQoIQ&sig2=2t3ZqNxLVT8Y4RJ6nKolmA
Mar 21, 2011 | Panasonic Shiatsu Massage Lounger with...
The power led light keeps flashing
Hi.
Give it a good 'knock' on the back (hard surface). You might hear a clink sound. I think it's when a cog gets out of line. My chair is fine now. You'll notice that the rollers start moving back to the off setting. So if it goes off and they are in the middle or top then it's stuck and needs a thwack!
Dec 01, 2008 | Homedics SBM 300H Therapist Select Shiatsu...
Holding question
First, select a wide massage area, and use the roller surface. Slowly movethe head of the massager over the massage area in big, wide circles. Then,for areas of soreness or stiffness, change the massager to the proper mode (Some massagers have two levels) . Push down on these massage areas for about 5 to 7 seconds for eachsore spot. Finish with the roller surface again, moving the head around theextended massage area in large, uniform circles.
Aug 27, 2008 | Jobri Dolphin Handheld Massager
Low memory msg
Happened to my n73 too. What you have to do is format the phone memory. Back up all memory on the phone to the memory card first before you do so.
To format:
  1. turn phone off.
  2. hold the following keys WHILE its turning back on: (3 + * + green call key)
  3. do not let go until it asks you about your location
Your phone will gain 44mb back and go back to normal. :)
Jul 27, 2008 | Nokia N73 Cellular Phone
Human Touch Ijoy 100 Robotic Massage Chair Camel Logo
94 people viewed this question
Top Human Touch Furniture Experts
ray gallant
Michael Vincent Cruz
Are you a Human Touch Furniture Expert? Answer questions, earn points and help others
