My maytag atlantis mav8600 wont go into spin cycle
It did this last week . i started it from the beggining of the wash cycle several times and nothing. i let it sit overnight it worked. i washed 3 more loads and back to the same, no spin cycle. you can hear the motor going but no spin.
This happened to us several times before we figured out what we believe is the solution -- the drain hose... It can't be too high, too low, too far away, to suctioned to the drain pipe etc. We've found that any problem we've run into with this machine has been due to the drain hose. We now have it taped to the wall in its exact preferred position and have had no further problems. This fixed our "no spin cycle" problem, and our "tub fills and then won't drain" problem.
Posted on Oct 18, 2008
    Scholar:
  • 97 Answers
Hiya
the first thing i would check are the carbon brushes in the motor, as it sounds like they could be worn down and are in need of replacing.
if the brushes are ok it could be the coil inside the motor breaking down, in which case the motor would need replaced
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 05, 2008
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
White flakes in circular pattern under washer of 7 years. Time to replace?
First we started hearing a grinding sound during the spin cycle. My husband replaced the belt, which was loose and not helping the spinning of the tub any, thus much wetter clothing after spin cycle. The belt gave us another week of use out of the machine and did drain the tub better, but then water started leaking into the tub from the water inlet (or area where water rushes in to fill tub), and was not up to the usual "rush" of water, when filling up. The grinding sound started again during the spin cycle, and so now we are assuming it is the ball bearings or the brakes and perhaps the water pump as well. Estimates for these jobs on the boards seems to run from $400-500.00. The machine is only 7 years old, but after reading so many posts, maybe I should count my blessings that it lasted that long! This was an all mechanical machine, which I loved. Atlantis Maytag, a very sturdy and solid looking machine. Never did really clean that well though. SOLUTION: we are getting a new machine.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
No rinse or spin cycle
hello
you have to change the lid switch
as soos as possoble
bye
Mar 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Jul 23, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
