What is the value of CR4095 in the samsung tv circuit ? A line is present in tv screen in side and this above capacitor is burn.
SOURCE: samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Posted on Sep 25, 2007
ser71
  • 818 Answers
SOURCE: Burning smell
you must contact a dealer, please go to this page
http://www.zenith.com/index.asp?url=./jump_dealers.asp
Sergio
Posted on Mar 06, 2008
kakee
  • 1269 Answers
SOURCE: Samsung HL-S6187W 61 in. HDTV black screen on the right side
If you found a bloated capacitor on the circuit board, that one needs to be replaced not the board. You can see the part number on the capacitor itself. Also please look for any burned IC and neighboring components. If you found additional burned components, it also need to be replace. Contact a pro tv technician to replace it.
Order parts here:
http://www.partstore.com/Sitemap/Generic/Television+parts/Television/Television+parts/television+parts.aspx
Posted on Aug 30, 2008
  • 280 Answers
SOURCE: insignia tv-30 inch ---model is-tvhd30 has burned
If it is in the power supply better check the rest of them. most should all be the same value so you may be able to get the value for the burnt one from that. good luck
Posted on May 01, 2009
  • 5 Answers
SOURCE: Tv is dead when i seen the circuit C 258 is burned i need the con
most of the caps that go bad in these sets are 1000uf @16v there are uselly 3 in the power supply
Posted on May 28, 2009
In LG 21" CTV, there is no raster on screen and sound is normal. When increasing screen of FBT only plain raster with retrace lines are appeared. when measuring voltage at cathode of CRT, picture apears...
Hi
Please try testing each voltage of RGB output in the small pcb attached to the CRT. If one of these voltages is missing (they are tipically almost of the same value), replace its output transistor. If all voltages are present, but very high (above 180V), please check the filter capacitor in the RGB supply voltage line near the flyback transformer (47uF/150/200V) by replacing it. It is cheap.
Please be careful when dealing with high voltage section of a tv set as capacitors may store a letal voltage. So disconnect the set from main and discharge any capacitor before dessoldering it.
If this helps you, I shall be glad.
Sully
Sep 26, 2013 | LG Televison & Video
Horizontal black line running entire screen an 4 more lines running vertical
Hello
This type of fault in Plasma TVs are of power supply regulator capacitors. If any one of these DC capacitors, go low in rated value, proper smoothin of DC power does not occur. and black bars across the screen fro top to bottom will be the result. Just check for any capcitors of it power retulator side for bulged out or leaky. You have to open the TV to see whethere there is any of them is damaged. OK.
Jan 30, 2011 | Samsung 50 in. Plasma TV
Tv has horizontal lines on top of screen.
Hello
You are seeing vertical retrace lines on the top of your TV screen.
There are mainly three causes for it. I don't know the age of your TV. The first cause is due to the supply voltage lack to the video output state. You can check it on the picture tube base card. You haven't mentioned about the diamension of your TV screen. So it can be say as a guess. If your TV is 27", the voltage mantioned above will come to about 245VDC. If there is a great voltage loss, check the smoothing capacitor to that supply, will normally come to the value of 10MFD 450V.
The second one is, capacitor related to the vertical output stage of your tv. It is in the circuit board. Normally these capacitors are situated in an area, which will get hot during working. As s result, there is a chance to the value change of their capacitance. It is best to replace all of them, as it may not cost too much. Before desoldering it out, mark the value of each capacitor is best. Normally replacing the filter capacitor 3300MFD or so,to the power supply to the vertical output Ic will solve this problem.
The third is related with the vertical output Ic itself. Just check all the soldering points in the vertical output section of your tv board. Anyway, resoder all suspected soderings by applying a little more solder, as bad solderings to the legs of the Ic or some other components also may the cause. OK.
Nov 10, 2010 | Toshiba Televison & Video
What are the locations for the capacitors on the LN26A330 power supply circuit board? What capacitors go in what location.
All the capacitors will have location numbers printed on the bottom and top of the circuit board next to them like C18 etc--the values of each will be printed on each capacitor--as well as one side of each will have a strip with - which means it is the negative side of the cap and the other side will be the + or positive side--look for ones that are puffed up on top---see attached photo of a new and good cap--the silver top with the creases should be perfectly flat.
Any bad ones should be visible to the naked eye.
Let me know what you find---if you find puffed up ones they will be marked also with a value like 1000 mfd (microfarad) at 10 v (means the cap is rated at 10 volts.)
If you find bad ones it is a good idea to replace with a higher voltage rated cap of the same value--it may present a small problem as the higher the voltage rating is the bigger the part will be.
The reason (if you have puffed up ones) they fail is because too low a voltage rated cap was used when the set was made---saves the company who makes the sets a few cents on each part.
Let me know if you have questions of need advice.
SD TECH
note the gray band on the left side--negative lead (each has 2 leads) is indicated that way.
Feb 12, 2010 | Samsung LN26A330J LCD TV
Samsung LE32 tv does not turn on. blue indicator light flashing
this is a common fault take back of and look on main power board for blown capacitor's ( raised tops ) they look like little batteries with white line down one side replace then with same value e.g ( 2000mf 25v)
remember what side line is on (TAKE PICTURE) for capacitors look on Charles hyde and son web site(CHS) under general components listed on left side of page
Dec 13, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Magnavox 27" TV- Burned Capacitor
For a schematic diagram, contact Philips directly.
Oct 04, 2017 | Televison & Video
Sony KDF-E55A20 Pink vertical lines
dear, the circuit for controlling speed is affected and that circuit is composed of passive componets inductor, resistor and capacitors. the only possibilities is to check loose connections a round the line transformer and around the vertical section. also check and measure the values of your electrolitic capacitors, cause these also change values when wax finishes in side them.
check that and contact me for the out come.
thanks for asking fixya.
okay.
Dec 03, 2008 | Sony KDF-E55A20 55 in. LCD Television
Dead tv
how come the on-screen channel display turns orange or blue instead of yellow ans I can't get any channel or play video - Sharp Mdl. 20V-S100 TV
Oct 18, 2008 | Televison & Video
Order parts here:
Aug 30, 2008 | Samsung HL-S6187W 61 in. HDTV
Distortion in Monitor
Your problem is simply a leaky capacitor on the vertical oscillator circuit on your monitor. Try replacing the ones with 10uF values.
Aug 10, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
