Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I'm trying to copy, delete or even format my 2gb kingston flash drive but the message shows that the device is write protected
  • 1257 Answers
SOURCE: write protected
First try to see is there any lock in your usb pen drive and see if its not locking the pen drive, because some pen drives comes with that option to protect usb .it looks like slide switch .for one end it will lock the media and when you switch to other side you have the full access
but if that's not the reason it might be the problem with registry
Use the Registry Hack to Disable Writing to USB Drives
Here is the link .just download the zip folder and after opening the folder you will find a file just double click on it..
http://www.howtogeek.com/wp-content/uploads/DisableUSBWrite.zip
Low feed backs hurt my ratings and I tried my level best to resolve the issue. so show your appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 11, 2008
  • 7 Answers
SOURCE: HOW TO FORMAT A WRITE PROTECT USB DRIVE
try this tool HP USB Disk Storage Format Tool!!
Posted on Feb 25, 2009
rustysheriff
  • 344 Answers
SOURCE: Remove the write protection on 2GB USB Kingston Data Traveler 100
Found this on Kingston site, doesn't help much but may point you in the right direction.
Unfortunately this unit does not have any security or write protection feature. If you receive a write protection message with this drive, check for the following:
  1. Verify that you are allowed to write to removable storage devices. There may be a security setting in the OS that disables write access to removable storage devices.
  2. Make sure you have not enabled write protection on the drive by using a third party software.
  3. If none of the above apply, the drive may be defective.
Posted on Jun 02, 2009
  • 1011 Answers
SOURCE: can't formated 4 gb sandisk usb drives
dear,
Follow these instruction and the work will be done..
Click start
Click Run
Type "CMD"
Hit Enter - A black screen should now appear (this function can be achieved by selecting Start---->Programes---->Accessories---->Command Prompt)
Type "diskpart"
Wait untill you get "DISKPART>" then type in "select volume (blank)" fill in the blank with the letter of the drive you are trying to remove write protection from
Now type "attributes volume clear readonly"
Remember select correct letter otherwise u will loose data of other drive..
e.g; if your Flash USB drive is F then type F there..
goodluck..
hope it will fix the issue so dont forget to rate it.....
Posted on Aug 09, 2009
laikexpert
  • 281 Answers
SOURCE: Kingston DT 101 II Usb Device become SKYMEDI USB drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 02, 2010
I have Data traveler 102 8Gb of Kingston.I used the usb for 1 year.But when i formate it with out keeping in view the formate options the formated with volume 4096 bytes.And when i copied files into the...
You will have to be the computer administrator to change any values on a hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Apr 23, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My Kingston 2GB USB is write protected. i dont know how to remove it coz i cant delete copy or format it
Check the USB device to see if there is a switch that makes it write protected. If so, change it back. If you're still having problems, it's probably defective.
Mar 16, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i remove write protection from my kingston datatraveler G2 2GB? thank you for your assistance
click start control panel administrive tools computer management disk management right click on your drive select properties then security select take full control in windows 7
also
- Click permissions
hope this helps
don
Feb 24, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I can't to format my 8 G flash(message:write protect) i used the Repair_v2.9.1.1.exe ,but it message that the usb flash not found. plz help me
Any time you see "write protect" it usually means there is a small switch on the device which prevents deleting data accidentally, even by writing over it.
Look for a small sliding switch and flip it to opposite position. That should fix it.
Dec 23, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
2. Format
May 26, 2009 | Kingston Technologies 512MB DataTraveler I...
Not able to copy more than 1GB into 2GB Kingston SD card
Hi 1123sun,
Copy your files off the card. Then Format the card and select FAT32 file system. After the format is done try the card again and see if you can copy more files to it.
Kingston Tech Support
Feb 18, 2009 | Kingston 2GB Secure Digital Memory Card
How can I delete write-protected files in pen drive
my multi-card (SD) kingston 2 GB is unable to copy , delete and format. It is always say that your multi-card is write-protect. I try to delete some file on it. It is able to delete but i reconnect to my PC,it shows my previous deleting files. why? If you have time , help me please.
Aug 07, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
REMOVING WRITE PROTECTION FROM MY USB 2 FLASH DRIVE
Hi, I am having problem copying or deleting from my Kingston Flash USB 4 flash drive. suddenly I could not delete or even copy anything into the drive. It keeps on indicating your disk is write protected. I have not secured the disk with a password, even then I have this problem....
How can i recover in this problem.
Jul 04, 2008 | iLO (2 GB) MP3 Player
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
22 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
