Question about Hobart Food Mixers
How can I read the serial numbers on Hobart mixers to get the year of manufacture?
bigg t
  • 640 Answers
SOURCE: Hobart A-200 serial # ?
I'll see if theres any info tomorrow.
Posted on Mar 02, 2008
ricardok45
  • 135 Answers
SOURCE: How to find the age of a Hobart N50
Hi Anne. Call your nearest Hobart parts place. The parts guys will be able to tell you the age and which plant it was manufactured in in the USA. Another source is the hobartservice.com website, look for discontinued products under the food machines group, then select mixers and browse until you find the file that dates machines. One thing to watch for when buying is oil leakage that appears to come from the bottom of the stand. This indicates that the transmission grease is partially separating the oil out of it and it's leaking out of the rear bearing and dripping down. If the leak seems excessive, pass on the purchase. This drip could also indicate excessive wear on the bearings. Also run the mixer in all speeds, if is sounds like a tank approaching, it probably needs a rebuild.
Posted on Dec 13, 2008
  • 49 Answers
SOURCE: more info re: n50 hobart mixer
N-50 have very good motors the do have one non metal gear its made out of fiber. its the main gear that drives all 3 gears. are they woth 2,000.00 No way. you can get a used one on Ebay for far less. look for one with a round black ball on the shift handle not the all metal this will be one thats not the oldest as the oldest can be a big risk. and parts are more availble on the changes over the years such as the on/off switch look for a toggle switch not a plastic what looks like a wall light switch.
Posted on Dec 29, 2008
bigg t
  • 640 Answers
SOURCE: service manual for hobart mixer s301
Give me the serial number,also hobart does'nt release their service manuals to the general public.However if you goto hobartcorp.com type in your model which is a d300 and you can access an exploded view of the parts.I work for hobart and service these mixers often.Any questions let me know.
Posted on Mar 30, 2009
  • 297 Answers
SOURCE: Age of Kitchenaid K5A mixer
1980
Posted on Jul 15, 2009
Year of manufacture
  • The K5SS was manufactured from 1978 to sometime in the 1980s (don't know if it made it into the 90s). Hobart sold its Kitchenaid division to Whirpool in 1982. If yior mixer has the Hobart logo on it then it was from 1978 to 1981 9 or 2. If it is identified only as Kitchenaid then it was made after 1981.
Jun 01, 2014 | KitchenAid K5SS Heavy Duty Commercial...
I need to know where to get original color paint for Hobart D300 Mixer
The place to get it would be, Hobart itself.
You will probably need to call their number as this is not considered a service item but they will have it. Simply because they use it for manufacturing their items.
Here are the number for the corporation
888-446-2278
937-332-3000
Here is the Website Link.
http://www.hobartcorp.com/
Hope this helps,
Happy New Year,
Mark
Jan 01, 2011 | Hobart D300 Stand Mixer
Service manual for hobart mixer s301
Mar 29, 2009 | Food Mixers
Year manufactored
If you call your nearest Hobart Parts place they can tell you. If they refuse this simple request, log on to www.hobartservice.com and look in the discontinued products menu, select Food Machines then Mixers and sift through the files until you find the documentation for serial numbers/dates. The lists are not complete and stop in the late 1980's. If you're lucky, you can find out which plant manufactured it, as the first two digits of the serial number indicate where it was built. The serial numbers are not in code, so it's relatively easy to get a date if you do the math. While you're there, download the manuals for parts and operation. You won't find the service manuals..."Top Secret"! Good Luck! Ricardok45.
Dec 21, 2008 | Hobart N50 Stand Mixer
Hobart A200 Commercial Mixer
Manufactured in 1931. Want to sell it? My girl just opened a restaurant and needs one... All the best.
Nov 20, 2008 | Food Mixers
Grinder attachment
Cindy,if it has a screw take it out,grab a flathead screwdriver and work your way around the cap.Some mixers have been painted or just the gunk over the years make the cap hard to pull off.The push button i have never seen on a hobart mixer near the hub.Give me the serial and spec number.
Nov 12, 2008 | Hobart A200 Stand Mixer
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
Mar 02, 2008 | Hobart A200 Stand Mixer
Hobart A-200
goto this site http://www.hobartcorp.com/default.aspx. you will find a parts list/view. before ordering any parts i would call your local hobart branch because the part numbers have changed.make sure you have the ml number or spec number found on the data plate before hand so youll get the right part numbers.any questions let me know,i repair alot of these mixers im a hobart service tech.
Nov 12, 2007 | Hobart A200 Stand Mixer
Food Mixers Logo
1,736 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
