It wont connect my laptop to home computer,it says its not discoverable
Is there a download for windows xp for bluetooth devices
Add a Bluetooth adapter to your computer, make aBluetooth enabled device discoverable, and then connect to that device
Sep 03, 2014 | Microsoft Windows XP Home Edition
Make wireless printer discoverable
First, make sure that your computer is discoverable in network settings if you're using a PC. If you're using a MAC it should see it automatically and ask you if you would like to connect, just follow the prompts. In windows you have to add it to your network and you can do this by going to the Windows help and type "How do I connect a Wifi product to my network" and you should find step by step in structions on how to do this.
Dec 14, 2013 | Coby Tablets & eReaders
Bluetooth is paired. Works for about 1 day. Then will not connect again.
Did you try the "Device Discoverable in ___ secs?".In settings, Make device discoverable first then set the length of time. Android phone have this limited BT capability i think.
Nov 14, 2013 | Motorola Mobility L512bt Cordless Phone
How can I enable the Bluetooth in my handa forza 2007 motorcycle?
follow this instruction. God bless you
To turn on Bluetooth discoverability, first key on the motorcycle. Leave the kickstand down and the kill switch off to keep the motorcycle disarmed. Toggle the Mode switch back and forth between Eco and Sport modes at least 12 times. Once the motorcycle is discoverable, the green "Armed" light will flash for a few seconds (except on FX and XU models. With the FX and XU models, the red warning light will blink slightly faster). It may take up to 10 seconds for the motorcycle to become visible to your Bluetooth device.
Once discoverability is enabled, the motorcycle will remain discoverable until paired with a phone, or until the motorcycle is switched off. Once you have paired your phone with the motorcycle, you will not need to repeat the discoverability process to connect to it.
Jul 20, 2013 | Computers & Internet
Tring to download music on my ipad off of bearshare and my device wont connect to the computer,bearshare wont connect my device how do i connect my device
First, in order to pair the iPad to a Bluetooth device you need to make sure the Bluetooth device is discoverable. Refer to the instruction manual for the device (which you can find online usually if you lost it) on how to do this. Typically, it just involves holding down a button for a few seconds. Next, you need to turn the iPad's Bluetooth capability on. Go to Settings by touching the Settings App icon that looks like gears. Within Settings, select General and then Bluetooth. Once you are in the Bluetooth screen, press the on/off switch to turn Bluetooth on. Make sure it reads "on". Once you turn on Bluetooth, you should see the discoverable Bluetooth device show up on the screen as part of a list. Select the device you wish to pair with the iPad. Depending on the device, it may prompt you for a password. Refer to the Bluetooth device's product manual for this password.
Hope this helps you
Sep 04, 2011 | Computers & Internet
How do i connect my blackberry to my acer tablet
Blackberry's don't really connect all that well to the Acer Iconia Tablet or any Honeycomb Tablet. The only way to connect is through bluetooth and there isn't much you can do when you do that either.
In order to do this you go into your manage connections on your blackberry - bluetooth connections - add a new device. You can either search or listen. If you search, you need to make sure your tablet is set to discoverable. Go into your settings - wireless connections - bluetooth - make discoverable. When it is discoverable click "search on your blackberry" When they find each other you input a code on each one (I usually do 0000 on each) and they will pair. After this the tablet will say paired but not connected but I think you can still transfer files over, but not easily.
Keep in mind that these steps might be slightly different depending on what versions of operating systems you have on both the phone and the tablet. Hopefully this helps and good luck!
Sep 03, 2011 | Acer Iconia A50010S16u Tablet Computer
New computer cannot connect to wireless
is there anything interfering with the signal? such as Tv senders?
Also there could be problems with youre router, whats the router make/model?
have you checked if the wireless radio is on? also if its discoverable?
Sep 09, 2009 | Computers & Internet
Problems of my printer not being 'discoverable'
A wireless printer generally needs to be set up via a USB connection, first. Then, the connection needs to be configured for wireless.
Hope this helps.
Aug 24, 2009 | Canon PIXMA MP160 All-In-One Printer
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
