Question about Craftsman Vacuums
I don't want to pay to find out out to use my craftsman 9 gallon wet/dry vac. is there any free advice available? maryrbrewer@aol.com
    President:
  • 1,273 Answers
Hi, W/D here.
Every so often, people get a bit twisted up about this website, thinking that they have to pay for advise. What it is, is, those things are options, but if you just want to just throw out your question and wait for a response, it's free. And, here we are.
Go to http//www.searspartsdirect.com and enter your model number. This site will have exploded diagrams and parts lists for your vacuum, and will probably have a button link to your manual that you can download (for free!). Enjoy. Thanks for using FixYa, where folks really try to help!
Best regards, --W/D--
Posted on Apr 02, 2011
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
How to use 9 gal wet/dry for wet use?
to use for 'wet' use --- just remove the foam and paper filter from the inside of the unit. it is now ready for wet use.
make sure you let the unit dry out before you reinstall the filters and use it for dry use.
c...
Feb 15, 2011 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
QUESTION: I have a 9 Gallon Wet/Dry Shop & want to find out the "amp's" ?
read unit for watts, volts, etc. then simply google watts vs amps or volts vs amps. that should do it.
Sep 28, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
I need to replace a brush to operate the shop vac. Where can I find it?
true value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Jul 13, 2009 | Craftsman 9-17765 12 Gallon Wet/Dry Vac,...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vacuums Logo
48 people viewed this question
Top Craftsman Vacuums Experts
downhille
Andrew Taylor
Andrew Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
