Question about Cell Phones
Hi, my bluetooth headset got wet. Will it still work ? Can I still have it repaired ?
  • Donald Tucker Apr 02, 2011
    I don't have a solution but I do know from experience that a wet phone is pretty much toast. So are many other electronic components. Headsets are no exception but it might still work after it has dried for a few days.
Bluedio bluetooth service center in Bangalore
I purchased Bluedio I4 bluetooth headset a month ago and as I was out of town for a month the device was received by my mom and it was not unpacked. I unboxed it today and after putting to charge for 4 hrs I took of the charger and tried to turn on the bluetooth by pressing the call button but it does not turn on. However it works only when it is plugged to the charger? What could be the problem? Have I screwed the device or is it a device problem?
Regards,
Sajith.
mail - v.sajith1988@gmail.com
Feb 21, 2015 | Radio Communications
Bluetooth pairs but will not connect
Try pairing and connecting with another headset. Or delete the pairing and pair again.
Mark
Motorola Support
Aug 21, 2014 | Motorola Mobility Hx550 Bluetooth Headset...
Music player through my bluetooth
Hi Mike Cronk,
I see that you have a Bluetooth Headset and that you are tryingto connect it to your BB.
You mentioned it will not play or you cannot hear Audio From it from your BB?
Did the Bluetooth Headset sync to your BB? you need to make sure that the headset is sync properly on your BB and that the BB is dectecting your Bluetooth Headset. make sure that the BB is also set to be detected by any device for the Bluetooth to detect your BB as well for proper syncing of both devices.
try your Bluetooth headset on another devices as well see if it will sync to a different device just to see if the Bluetooth headset is working fine.
I hope this helps,
michaelvincentc
Dec 25, 2011 | Jabra BT2080 Bluetooth Headset
Hi, My phone has a headset mode on and i cant get it off. I dont even own a headset so how do I turn the mode off?
You didn't specify what kind of phone, but since most headsets now connect via bluetooth turning off the bluetooth service will disable the headset mode. Some phones have ability to use a headset that plugs into the phone as well. If the connector is dirty or gotten wet (corrosion), this can cause the phone to think a headset is connected.
Aug 21, 2011 | Cell Phones
Blutooth bh-700
Hello, the manual will almost always tell you the default verification code. In this case it's the generic default 0000. If this dosn't work, look at the manual below under 'Pairing'.
Actually here's the manual: http://nds1.nokia.com/phones/files/main_page/Nokia_BH-700_UG_en.pdf
Nov 22, 2009 | Nokia Bluetooth Headset BH-700 for all...
Motorola motorokr doesn't work
The mic stopped working on my S9 after 2 weeks and removing the BT device and repairing did the trick...try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). .
Mar 27, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Samsung Bluetooth WEP210 and Blackberry
If you have lost the pairing on your Blackberry with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the Blackberry
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The Blackberry should search for any available Bluetooth devices and display what was found
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the Blackberry
Hope this helps
Chris (ziraffa)
Dec 15, 2008 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Samsung WEB410 bluetooth headset won't hold charge anymore
Well if it holds no charge you will most likely have to replace it as it is the battery inside the bluetooth headset in otherwords the battery is buggered lol. do you still have the headset and the charging cradle?
Oct 15, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off.  Try holding both volume buttons at the same time for a second or two.  If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up.  On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume.  My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
Sep 29, 2008 | HTC Touch P3450 Smartphone
Cell Phones Logo
308 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
