Question about Fisher and Paykel (IWL12)
Fisher and paykel gw612 won't empty or spin - Fisher and Paykel (IWL12)
    Problem Solver:
  • 8 Answers
Check Drip Dry option not switched on or for obstruction in pump chamber or outlet hose. Possibly burnt out, seized or open circuited pump.
Posted on Apr 02, 2011
Fisher Paykel washer won't spin and drain. Any solution? Error looks like no E AP
possible answer for you see the link after reading Error/Fault code 00000101. (The value is 5.) It wasnt draining the water out at the rince cycle. I saw comments on fixya.com that others with the same problem found clothing between the outer bowel & the inner bowel or an item such as a necklace chain or hairclip jamming up the propeller..... (Two days later, see part 2....) I just fixed this F&P GW612. There was a darning needle stuck in the drain motor pump stopping the propeller from spinning around. I fixed it for my mum by watching a couple of You Tube videos. Easy job to do. Took me about 1.5 hours including drawing out the water from the drum with a bucket & jug first. Lay the machine on a soft mat, remove the motor pump from underneath, clean it out. (You could find a foreign object such as a coin, cloth, rubber band etc.) Put it back together & test if it's pumping out water at the rince cycle by doing a low water wash cycle. So happy, job done & I saved my mum some money!! Fisher Paykel GW612 Not rincing spinning part 1
Mar 15, 2018 | Fisher Washing Machines
Hi I have a F & P washing machine GW612. It has the seventh light come up in diagnostic mode. Is that error 2 & how do i fix it please? Thanks
Here is the instructions manual which contains the detailed diagnostic code explanations from p.33 on.
http://laundry.manualsonline.com/manuals/mfg/fisher_paykel/gw612.html
Aug 26, 2015 | Fisher and Paykel Washing Machines
Need to do a reset on a gw612 after changing the cold valve
There is no reset for these.
If you are getting error code 48,49,50
your motor controller board is faulty.
Feb 21, 2014 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel GW612 won't spin
you want to check the drain pump if there is nothing stuck there sometimes a drain restriction will cause the machine to stop
Jan 27, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Jun 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel gw612 fault 0000X0X0 can any one help X is light on on control board
click on this link directly to get the user manual of your product http://safemanuals.com/user-guide-instructions-owner-manual/FISHER%20%2526%20PAYKEL/GW612%20-_E in this link there is mentioned all types of troubleshooting and error code list. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 30, 2009 | Fisher and Paykel Washing Machines
Washing Machines Logo
329 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
