Question about Diesel Audio Car Audio & Video
The face of my car stereo model number NS-9915 does not work...it only allows me to turn the volume up and down..sometimes
dodgecharger
  • 254 Answers
SOURCE: car stereo cuts out
It is possible a self-protect feature may be shutting down output. Check all of your wiring, following the manufacturer's instructions exactly. Faulty wiring is a major cause of poofed audio output devices in car audio. Any short in wiring, or an open (intermittent or otherwise) can cause a problem here. Internally, bad solder connections where the output devices solder to the board could cause problems too.
Posted on Jul 03, 2007
SOURCE: bellsouth 9915 Manual
Well, chopping off the URL isn't going to help!! Here it is again:
http://www.amazon.com/BellSouth-MH9915BK-900MHz-Cordless-Phone/
dp/B00005U23W
(type or copy the whole thing)
Posted on Feb 26, 2008
  • 10 Answers
SOURCE: model krc 777r car stereo
sounds like the ribbon cable has gone out to the controls. can be repared but really not worth it
Posted on May 29, 2008
bernardlunda
  • 318 Answers
SOURCE: my toshiba model number 35a44 when turned on the
the audio amplifier is faulty,
change the IC for your amplifier out put.
Posted on Apr 08, 2009
Remmik
  • 56 Answers
SOURCE: amp guard on stereo?
    I found this simple message on "TeamClarion" site when I had an "amp gaurd" issue.
    Step 1: Disconnect all the speakers2_bing.gif from the head unit and try again. If the same message comes up, send the unit in for service.
    Step 2: If the message goes away, you have a wiring problem. Check each speaker lead for a short circuit, damaged speaker or a ground to chassis.
    Basically means one set (or more) of the speaker leads are touching each other (shorting out). This can be somewhere inline to your speakers or your speakers them selves. The advise above isn't to clear. In the first step they want to rule out the speakers attached but "disonnecting all the speakers" is vague. You should disconnect at the rear of the radio. This might be difficult because the multi plug in the back has the speakers and power wires together (at least most clarions). Also if it was a good install then the outgoing speaker wires were soldered to the long run speaker wires going to the speakers.
    To truly test for radio fault verses the wiring or speakers, you have to sever the connection at the back of the radio. If this is not something you wish to do then there is one suggestion. Order a new multi plug for the back of the radio. This way you can pull the old plug and test it with a new plug with no speakers attached (just have to run 12v positive and negative).
    If the radio is OK then start by checking all the wires to your speakers (if possible). If nothing seems bare and shorting (remember it's usually in tight places or were the wires are hanging loose that vibration will cause cutting to the wire) then disconnect all your speakers (at the rear of the speakers). Turn the radio back on and see if it does the error message2_bing.gif again. If not reattach the speakers one by one checking for the error message.
    You can check these in any order. If you don’t want to order a new plug then you and can’t get to much of the wiring to physically check then starting at the speakers is OK.
Posted on Jun 03, 2010
Volume on 1999 Nissan Altima
fine tuner spray in the switch
Jan 28, 2014 | Nissan Altima Cars & Trucks
My car stereo has Bluetooth but i don't know how to switch it on.
Model number is needed. Try this one: Press MENU button and hold. When Demo appears, turn the volume to select and press the volume to set.
Aug 25, 2013 | JVC AM FM CD DET FACE CAR STEREO
I have a Panasonic CQ-C8100U Stereo. Was working fine then the auxiliary jacks stopped working. I Can power down then it sometimes works then doesn't once the volume is turned up past 13. Any...
hi robert. if your aux jack is mounted on the front of the face then i assume you have a problem within the face, maybe a cracked pc board, a switch which has lost its "click" feel, or even dirty gold face contact pins. also make sure that none of the 8 speaker lines is touching/shorting to the ground level. lastly have all your speakers checked independantly. cheers.
May 02, 2013 | Car Audio & Video
I just got a new Diesel Audio NS-9915, I dont have manuel so I can not set clock or adjust sound I need help! Please
go down to auto zone or advanced auto napa ect!!!
order a haynes repair manuel
they cover every thing from (codes) to electrical
motor / transmission / rear ends / drive train
i find its very informational
hope this helps you
good luck
bob
May 08, 2011 | Diesel Audio Car Audio & Video
I connect my car stereo and the speakers don't work
Not to be rude but is the volume turned down or mute on? Take the deck out and check all your speaker wiring. I would use screw ons for proper wires being terminated together.
Sep 20, 2010 | JVC AM FM CD DET FACE CAR STEREO
I have a JVC AM FM CD DET FACE CAR STEREO. I just
model number would be nice but i'll give it a shot. hold down the volume button for 4-5 secs and that should pull up a psm menu. clock settings should be in there.
Mar 17, 2010 | JVC AM FM CD DET FACE CAR STEREO
Insignia NS-C5112 manuel. new sub getting too much sound through rca wires when turned up. sub amp shuts down. need to tune down audio in rca cables
does your new sub have a volume or gain control? If your getting the signal source from the line outs, then the volume level there is constant. You need to set it up so that it can be controlled by the main volume control.Or you might need a control pre-amplifier before your sub
Aug 18, 2009 | Car Audio & Video
Cd tray opens/closes by itself, intermittant full volume at start
I have a few ideas, but the model number is required for me to provide details. Can you please update this with the model number? Thanks, Dan
Jun 16, 2009 | Aiwa Audio Players & Recorders
JVC KD-S15 setup - How do I turn "Demo" Off?
press and hold the sel button....select an itenm (useing the silver button beside the volume dial).....then use the volume dial to adjust ,time , demo alot of others...then press sel button to finish.....this is straight out of the instructions...hope it helps you
Dec 28, 2008 | JVC AM FM CD DET FACE CAR STEREO
Car Audio & Video Logo
Top Diesel Audio Car Audio & Video Experts
armando martinez
Level 1 Expert
Tom Chichester
Are you a Diesel Audio Car Audio and Video Expert? Answer questions, earn points and help others
