Question about Refrigerators
Fan motor blowing cool air. Freezer thawing out.
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
Refrigerator part not keeping cold- freezer freezing. I unplugged it . Cleaned the freezer and thawed it out. It seems ok but the refrigerator part is not cold.
There is a fan that delivers cold air from freezer to the fridge section. if freezer is working fine, and fridge part is not cooling replace the fan motor/fan
Dec 29, 2016 | Refrigerators
My freezer is working fine, but my refrigerator is barely cool and both units are controlled by the same setting knob. This just happened all of a sudden. Everything in the refrig is spoiling.
It the fan blowing up in the freezer and no cool air is coming down to the fresh food section then I have seen this before. The drain for defrost is clogged. Instead of draining out it is pooling up between the freezer and fresh food side. You gotta thaw out the ice box and open the drain. Nothing to buy. Oil the fan motor with zoomspout oiler.
Jun 29, 2011 | Whirlpool ET1MHKXM Top Freezer...
I have a Samsung RF268ABRS Unit all food in bottom freezer thawed. Unit is running and ref is cool. I notice that the fan dosent seem to blow. Closed freezer up and its cold, but no air moving. How do...
I had a similar problem. my samsung freezer would only cool to 20 degrees, which also resulted in the freezer ice maker not functioning. (fridge door ice maker still worked) If you hold the power freeze and power cool buttons down together for 8 seconds it will a diagnostic. found the answers on http://appliancejunk.com/forums/index.php?topic=8206.0 , as too what the codes meant. Mine was throwing a freezer fan code error. ordered one online $30 and replaced it. seems to be working. TIP -The fan is located behing the rear panel in the freezer. I had two fans. The regular looking one is the freezer fan, the squirrel cage fan feeds the fridge ice maker. Also the new fan motors don't come with blades, just pull the blades off the old one and put it on the new motor. Don't push it on too far, make sure there is enough clearance so it spins freely.
Jun 28, 2011 | Samsung RF267AB (25.5 cu. ft.)...
The freezer is freezing but the fridge is not cooling
You have a bad fan motor that needs to be replace.
It's kind of a hassle because you will probably have to remove all the stuff in the freezer and completely thaw it out to get to the fan motor that blows air from the freezing compartment to cool the refrigeration. You might get lucky and find that the fan blades are just frozen up and the motor is not burned up as a result. (Hopefully) Then all you have to do is plug it back in and test to see if the small fan blades rpm.
Motors are available at the Sears Parts Store or on line. If the freezer is on the bottom it's easer to work on.
In any case, in the future you will want to defrost your freezer a 3 - 4 times per year to prevent this.
Cheers,
TF
Jun 02, 2011 | Maytag Refrigerators
Freezer working fridge is warm fan not blowing
ur solving ur own problem the fan either needs to be thawed ,lubed,repaired or replaced the fan uses the air from the freezer to cool the fridge side but bench test the fan before replacing if fan good than check the thermostat in fridge for proper working order
Nov 26, 2009 | Montgomery Ward Refrigerators
Fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Nov 15, 2009 | Avanti Top Freezer 9.9 Cubic Foot Total...
Side by side fan in back doesn't
A temporary solution for this, is to use a fan to blow some air to the back of the unit. Looks like -as you already figured- the condenser fan is broken. If your fridge starts cooling with the external fan, you may have keep it working on this way until it is fixed.
If you had previous service in your appliance, perhaps the tech guy forgot to plug the fan connecto to the power.
Aug 30, 2009 | Hotpoint Refrigerators
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Jul 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
Frigidaire Side-By-Side Top Not Cooling
the unit is loosing the freon supply to the evaporator.you either have a leakage,a blockage or the compressor is not pumping to full capacity.
Nov 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
