Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printer/Scan Hi, I am not able to find my CD software to reprogram my PC to scan with my HP All-in-one printer. Is there a way I can either order another CD software or make this scanner on HP work with my PC? I lost all when my PC crashed, now I am not able to fine the CD software to download it all again. I am still am to set up with the printer and it works fine for printing. Thanks!
  • gemond1 Aug 07, 2008
    Can't find software site.
  • 50 Answers
You can download the software using the link given below .
http://tinyurl.com/ykr3qj
This link will walk you through with the steps.
Posted on Aug 05, 2008
I cannot find a way to scan from my computer (HP) to my printer (HP). There is no icon on my screen to get to the scan part of my printer.
Dear christian, I think you have not installed full software of your HP printer. So insert the CD provided with the HP printer in your CD rom. It will autoplay. Select the install and than easy install option. In this process full software will install in your PC. After that you can find every function of your printer in your PC. thanks...
Sep 01, 2011 | Computers & Internet
I am not able to scan from HP Laserjet 3055 to e-mail. It tells me that scan.msi is missing. All the websites I go to want me to download something that will scan my computer. i have fallen into that...
Uninstall the printer software then reinstall it. If you don't have the CD that came with the printer, you can download the printer software from hp.com. Click support and drivers, type in your model, then search for the printer software for your PC. You have to select your version of Windows operating system, then it will list the printer software for your PC.
May 02, 2011 | HP LaserJet 3055 All-In-One Printer
I have an HP Photosmart 2575 and the message "refer to device documentation" appears when I try to scan. (Printer stopped scanning with installation of updated operating system) I use Mac OS X version...
The printer scan button wouldn't work for me either. I had to install the HP Solution Center software from CD onto my Windows Vista PC then I use its scan document software button to do any scanning.
Feb 26, 2010 | HP Photosmart 2575 All-In-One InkJet...
Hi I'm not able to fax from pc or scan HP5610
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9ofdfd5
Jul 21, 2009 | HP Officejet 5610 All-In-One InkJet...
HP C6280 won't let me scan to the computer. Only options are "Scan & Reprint" or "Scan to Memory Card". I just want to save image directly on my computer but it doesn't let me. I've uninstalled and...
ergo your problem!!
You must have scanning software installed on your PC in order for the 2 devices to communicate. It should have come bundled on the CD you got with the printer. I believe the HP software is called HPDirector.
Please find on your PC or install from your CD & that will enable you to scan to your PC.
It may already be installed. You will need to run the software to enable communications between the 2 devices.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 20, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
I cannot scan documents
You have completely uninstall the HP 7410 printer software from the computer and reinstall the printer software driver either by software CD or Downloading the software from hp.com/support website.
Sep 08, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Hp software for f380
The drivers and scan software can be downloaded from here or there are also links to order the CD from HP.
The full download is about 163Mb, if you have a slow connection you may want to order the CD. Typically the CD is free but there is a shipping charge of ~$10.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 22, 2008 | HP DeskJet F380 All-In-One Printer
HOW TO SCAN ON HP PSC 1315
i have a Vista system and an old hp 1315. the CD driver that came with it includes some very useful software that cannot be installed in my laptop. according to the hp website, that's because Vista comes with a compatible software for my hardware. checking Windows Help & Support gave me this solution:
Open to Windows Photo Gallery, click File then click Import from Camera or Scanner.
i did exactly that and it worked!
i hope this was of some help.
Jan 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
47 people viewed this question
Ben Johnson
