Question about Campagnolo Cycling
I want to adjust the rear hub of my Campagnolo wheel. (There is a bit of play on it.) On the left side, I find a black ("plastic") cap that is secured by a srew. Undoing this, I dont find any nut or something else to hold onto.... On the right side there is a nut just sticking out of the sprocket but since I don't have anything to hold onto on the left... Do I make myself clear? Thanks for your response. Harrie vdH
    Brigadier General:
  • 8,546 Answers
How do you replace the rear wheel hub on a 2003 Kia sedona. All I can find is directions on front not back.
Wheel Bearings
Print
Adjustment
2002-05 Models
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear wheel Brake drum Hub cover Cotter pin Lock nut cover
  3. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm).
Removal & Installation
2002-05 Models
    Rear wheel Brake drum Hub cap Cotter pin Lock nut cover Lock nut Wheel bearing retainer washer and the outer wheel bearing Hub assembly Grease seal Inner wheel bearing
  3. Clean and inspect the wheel bearings and races for unusual wear or damage. Replace parts as necessary.
To install:
  1. Pack the wheel bearings with grease for assembly.
  2. Install or connect the following:
    Inner wheel bearing Grease seal Hub assembly Lock nut. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm). Lock nut cover Cotter pin Hub cap Brake drum Rear wheel
Apr 03, 2015 | 2003 Kia Sedona
Rear wheel assembly of my bike is shaking side ways
Sounds like loose 'cones' in the rear wheel hub. The cones are cone-shaped nuts that the bearings run against, being held in place within the hub in the 'cup' of the hub. Tighten the cones until there is free rotation of the wheel with no lateral play. Hold the cone in place with the spanner whilst tightening the lock-nut and recheck the adjustment. If you lack the tools take it to your nearest independent local bike shop and they will surely be happy to help.
Aug 25, 2014 | Cycling
Kawasaki 2007 kx 250 rear wheel play
I was thinking wheel bearing but you state they were replaced, are they tight in the hub? if your spokes are tight, your hub would be tight and if wheel bearing are tight everything would be correct when the axle is tightened. Your swing arm is tight as well not loose in the bearing.
Jan 24, 2018 | Motorcycles
Rear wheel bearings??
Yes. It could absolutely be wheel bearings gone bad. Any time a wheel wiggles more than a little bit that is the first place to check on the rear of the vehicle.
Jan 14, 2012 | 2004 Ford Expedition
Need to remove rear hub on rear wheel drive 04 ford transit with shoe brakes cause play in the hub
The brakes are adjusted out. There is a slot on the back side of the hub on the bottom in the six o'clock position. You can get a brake tool or use a screwdriver. It is two pieces threaded with a wheel in the center of it. You must turn it so it brings the shoes inward. Yo'll know which way it's turning after a little bit. It can be a challenge but take your time, get comfortable <-that's key and turn away. The drum should slide right off.
Jan 12, 2011 | Ford Transit Connect Cars & Trucks
Can you please tell me how to change the rear wheel bearings on a 1999 Vauxhall corsa van. The make and model is not correct it didnt have Vauxhall to choose from. Thank you Rob
yes sorry but you know the americans ,they dont do geography and they beleave in flat earth theory ,lose sight of land and the world stops ,yes easy job they are taper bearings on vehicle of this age and easy to change ,hardest part is knocking the bearing paths out ,when i service vehicles and i always take the back drums off to clean and inspect and adjust the auto brake adjuster i always put some engine oil in the dust cap before i refit to keep the grease soft ,anyway dont you know this is a opel not a vauhall -GB doesnt exist anymore across the channel but its a third world religious ethnic state of mohamed .
Jan 03, 2011 | Volkswagen Corrado Cars & Trucks
Steering wheel changes
Here is the simple steps to change the old steering wheel and install the new one.
Remove the Original Steering Wheel
1.Read instructions that come with the steering wheel, and gather the following tools: screwdriver, pliers and a puller.
2.Point wheels straight ahead.
3.Disconnect battery or pull horn fuse before removing the old wheel. This prevents the horn from shorting out or blowing during installation.
4.Remove the horn mechanism by doing one or more of the following steps: Press down on the horn cap or ring and turn; remove the emblem cap from its snapped-in position by grabbing it and pulling it toward you or prying it loose; or if the horn ring is secured by screws that are concealed in the rear side of the wheel spokes, use a screwdriver to remove the screws and the ring.
5.Remove horn wire or spring-loaded metal plunger from plastic housing by either pulling straight out on the metal plunger or, on most models, by twisting the plastic sleeve to the left and then pulling out. Cut the wire off the plastic sleeve and keep the sleeve for later use.
6.Remove the shaft-nut retainer clip, if it is present, and keep for later use. Remove the shaft nut, which holds the wheel to the shaft.
7.Mark the shaft at the twelve o'clock position so that you will know where to position the top of the new wheel.
8.Insert a conventional puller into the two tapped holes which appear in the hub of the old wheel and pull off the steering shaft.
9.Remove the original wheel.
Installing the New Steering Wheel
1.Place the small tubular metal sleeve down over the steering shaft.
2.Position hub on splined shaft, making certain that the shaft is properly positioned using the mark you made in step 7. You may have to rotate the plastic horn contact tube slightly to align it with the appropriate hole through the hub.
3.Insert plastic sleeve and spring from step 5 without wire into plastic horn housing. If the plastic sleeve extends above the top bolt surface of the custom hub, cut down the sleeve so that it is 1/8-inch below the top of the hub. Remove sleeve.
4.Insert through the plastic sleeve the wire lead that was supplied in the wheel kit. One end will not pass through the sleeve. This bell-shaped end will go into the horn contact housing. Insert the sleeve and wire into the housing and lock into position.
5.Route wire around the hub from the ten o'clock position to about the two o'clock position to properly align wheel. Position post cover and wheel on hub. Make certain that the wire lead passes through the appropriate holes in the two o'clock position. Using the three shoulder bolts provided, fasten the hub, post cover and wheel together, but do not tighten.
6.Check wheel for proper positioning. If correct, reinstall the shaft nut from step 6 and tighten. Reinstall shaft-nut retainer clip. If the retainer does not fit into the groove on the shaft, tighten the nut until it will fit as originally located.
7.Remove shoulder bolts and reinstall them through the retainer ring with the fiber side toward you. Tighten the shoulder bolts with caution - excess torque will result in damage to the hub. The shaft nut, if correctly tightened, will firmly hold the hub and wheel assembly on the shaft.
8.Connect wire lead to the connector on the retainer ring. Position spring on center nut. Align the dimples of the horn cap with reliefs in fiber material and push into the dimples past the fiber. Turn cap left or right until tight.
9.Reconnect battery or replace fuse.
Sep 09, 2010 | 1991 Honda Accord
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Feb 06, 2010 | 1990 Mercury Topaz
Replace cups in Campagnolo rear hub
unless you want to ruin or warp your wheel id take it to a shop with a press or tool to do it right
Aug 24, 2017 | Cycling
Front wheel slips off shaft
Pull the wheel off. Look on the back side of the wheel - you will see 4 plastic pins sticking out (inside the wheel) Use a pen to push on them - this way you will remove the hub cap without damaging it. Under the hub cap you will find the screw. You will need a torx T20 or Phillips crew driver (depending on what type of screw is there) to attach the wheel to the shaft with the screw. You can use a bit of a nail polish on the screw thread to keep from coming off again. DO NOT use glue or too much of nail polish or no one will be able to get the wheel of if needed some time in the future.
If hub cap nor the screw is there - you can find it all HERE.
Good Luck,
Rocky
Mar 24, 2009 | Kirby G6 Bagged Upright Vacuum
Cycling Logo
75 people viewed this question
Top Campagnolo Cycling Experts
Michial Gueffroy
jimmarmor_ma
Are you a Campagnolo Cycling Expert? Answer questions, earn points and help others
