SOURCE: scaner computer comunication
These are the steps for Windows operating system.
First make sure you have installed the printer driver software installed sucessfully untill it shows fax setup wizard and complets the entire procedure.
All you need to check is first open solution Center> Go to Settings> And Email Settings> Checked which is the default email selected there if you have outlook select it (But your outlook has to be configure to send Emails fom youe PC) then click on apply and close.
Then in solution center click on scan picture or Scan Document the in the next window where you see (Where do you want to send the scanned images) Click on the drop down and select EMAIL after it has scanned and you click on accept it should open the outlook window on its own where you can put the recepients name and send.
But if in case your outlook is not configured then try the bellow link to configure outlook:
http://www.hostmysite.com/support/email/outlook/
You can also send email from the printer but to enter email address you will need the computer to manully enter email address after it opens outlook window
Good Luck let me know if any problem
Let me know if any problem.
Good Luck
SOURCE: my scaner is given me a black picture
hi
chek this site for the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=79477
all the best
regards
SOURCE: i need hp officejet 5610
hi
download it from here
just choose your operating system
after that follow these steps
1. Disconect your printer from your pc
2. uninstall your printer driver from your pc
3. run the file you have download (with out connecting printer to pc untill setup ask you to)
If i had help you pls vote me
