Question about HP Pavilion a1250n (EG194AA) PC Desktop
Constant beeping and my computer will not come on ive cleaned it and changed the battery in the mother board any suggestions?
  • 961 Answers
Beep codes indicate a problem with hardware, most common is the memory. Listen carefully to the codes (1 long, 2 short, etc.) and either let me know or repost with your code. If you have your manual, it should give you the beep codes and what to check.
Posted on Apr 02, 2011
I have encountered a high and low beep from my mother board, what would be the problem of my board and solution of this problem? but before i have first encountered a constant reboot of my computer it just...
Remove your processor cooling fan from the processor, then clean the fan with high pressure air blow and clean the top side of ur processor, and get a good heat sink solvent {not the white one}
it will come in grey color 10ml package i think, and apply half of that and fix... Actuall mean for the siren is system halted with thermal shutdown...
Sep 17, 2010 | ASUS Computers & Internet
Turns on, then shuts down before anything shows on monitor
Hi m5mm, what kind of Operating system are you using?
Jan 03, 2008 | Gateway GT4022 PC Desktop
There is a continious beeping sound from mainboard; when on. sonds like from the bios or cmos. any ideas Thanks
most likely it is a sound from mother board
- try to reseat the mother board(take out and put it back in)
- then check if still getting a sound/beep
- if not good!
- if yes replacement mother board suggestion
TIP:
- try other mother board on your computer first to check if you can hear a wierd noise
Mar 31, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Long beeps like a vga problem
Good day sir, continous long beeps are not VGA problems, but the motherboard cannot detect a good valid memory module (ddr). I suggest you check out your memory, (ddr1 or ddr2) by cleaning its gold plate contacts, and using a brush, the memory slot. just make sure your memory modules are good. (reset also your CMOS)
Oct 14, 2009 | EliteGroup GeForce 6100SM-M Motherboard
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
ASUS K8S-MX PC powers up but no display on monitor and no error codes. Hard drives spin and sounds as if it is in boot routine
OPEN UR CPU AND OUT UR RAM FROM MOTHERBOARD AND START UR PC WITHOUT RAM IS IT BEEP OR NOT IF IT BEEP THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC IS IT OK
IF NOT THEN PICOUT BATERY CELL 2032 FROM MOTHER BOARD AND THEN START UR PC
IS IT BEEP WITHOUT RAM AND CELL IF YES THEN CLEAN UR RAM AND RE INSERT IN MOTHER BOARD AND THEN START UR PC
IF IT IS OK THEN CHANGE UR BATTERY WITH NEW ONE
IF UR PC BEEP WITHOUT RAM BUT NO DISPLAY WITH RAM THEN CHANGE UR RAM WITH NEW ONE.
Jul 01, 2009 | ASUS K8S-MX Motherboard
Mother board asus a7v133
Hi there.
No i doubt its the chipset but rather the system memory.
Pull the power cord from the back, open the side panel, get a clean dry soft paintbrush, take out the system memory and clean the brass pins and the ram slots of any dust that may have built up, then reseat the memory making sure it clips into place nice and tight and try to boot the computer up again.
If you still get beeps count how many there are and if they are long or short and post back here.
Good luck and thanks for choosing FixYa!!
May 28, 2009 | ASUS A7V133 Motherboard
No boot or beeps
clea your processor and then refix it.then alsom check with other ram may be your ram is faulty.also some times earthing problem creates problem in booting proces.
Dec 29, 2008 | Computers & Internet
CHANGED CPU SPEED ON MOTHER BOARD "FOXCONN 661M08-FX-6LS" AND NOW KEEPS BEEPING. CAN I RESET MOTHER BOARD. THANX
Yes you can reset it, just make sure you unplug the computer before doing it...
Open the left sidepanel and either look for the clear cmos jumper and switch it to the other pin for 10 secs, or you can remove the cmos battery for 10 secs
Sep 19, 2008 | Computers & Internet
No beeps,cd,flopy,monitor-can i use cleaning fluid on mother board?
Dear sir,
Have u changed the SMPS or not? If not change the smps & check it
Max.this problem related to smps only, in somecases problem may with motherboard also
Pl try it
was this soultion useful?show your appericiation by rating it.
Thanks
Mar 17, 2008 | Gigabyte 7nnxp Motherboard
HP Pavilion a1250n (EG194AA) PC Desktop Logo
365 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
