Question about Home
Moen eva tissue holder broke, how do we fix it?
    Genius:
  • 1,739 Answers
Specifications and Installation Instructions:
http://www.moen.com/shared/pdf/yb2808sp.pdf
Identify the parts needed and the part number from above.
To order replacement parts:
http://www.moen.com/replacement-parts/search?context=modelNumber&value=YB2808CH
If your tissue holder has simply come loose it is likely the the wall mount will need to be replaced or at the very least tightened. You will need to remove the tissue holder from the mounting bracket. Insert a small flat screw driver in the square hold at the underside of the base of the mounting post to release the locking tab. Try to tighten the screw holding the mounting braket; if it will not tighten you may need to replace the wall anchor. Once the wall anchor is replaced you can reinstall.
Posted on Apr 02, 2011
Can't get the Moen Eva towel ring fixture to release so I can move it.
check underneath for a small setscrew. back this out and it should be removable
Jul 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
Arm has come loose on 2 of 3 paper holders
Here are the installation instructions:
http://www.moen.com/shared/pdf/YB2808sp.pdf
Is it the connection to the wall that is loose?
At the bottom of the post; facing down to the floor; there should be a square hole which will provide access to the locking tab. Use a small screwdriver to release the locking tab to release the post from the mounting post.
To tighten the mountng post to the wall; besides just tightening the screw; you will likely have to replace the wall anchor. After going to this trouble suggest you use a suitable toggle model rather than a plastic plug that be more secure and long-lasting.
After replacing the wall anchor, reassemble.
Trust this is helpful. Please vote. :)
Nov 01, 2010 | Moen YB2808 Eva Paper Holder - Chrome
HOw do I remove the moen toilet paper holder from the wall
Without looking it up, I can figure it has a tiny screw on the flange bottom, and when it is loosened, it will come off, then the holder, keeper, is screwed to the wall. If it is not held on by a little screw, setscrew, then try turning the whole thing off, it might be threaded. Hope this helps.
Jun 11, 2010 | Moen DN0708CH Iso Pivoting Toilet Tissue...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
How does the holder detach? Allen wrench,star, push with a screw driver?What do you use to remove the holder from the wall?
there is no set screw or allen key for this. It is mounted in the anchor bolt by use of a mounting screen, pressed in until it clicks and difficult to remove
Nov 19, 2009 | Moen YB2808 Eva Paper Holder - Chrome
Home Logo
69 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
