Left side of screen shadowed, darkened and after being on for a few minutes horizontal lines appear and oscillate. I've only had this tv for 3 years.
  • cjsgray Apr 02, 2011
    thanks for your help. it is a philips lcd. now the screen is jumping. sorta like a strobe light. No burn in present. the whole screen has since darkened when the screen started jumping. Any suggestions???
    it gave me a starting point to what to do. thanks
    Genius:
  • 1,622 Answers
Sounds like burn-in. Yep, LCD TVs can have it too. If you look close, I would bet you will the channels that has the bars down each side line up pretty good with that shadowy line.I guess is Samsung TV I have spoken with Samsung about this issue in the past, they will not cover it.
Even though it's not Samsung TV,you can contact the service repair teamfor the make of you TV they will help you out.
Also,Is it an LCD or DLP? Sounds as if you have the dreaded light tunnel collapse common to all DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Posted on Apr 02, 2011
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Apr 02, 2011
    Your
    power supply board is not yet dead, u know basic electronics' and
    soldering? Most of the times, the power supply board just have dead
    leakages gases capacitors.These capacitors always bulges up on it top,or
    puff up on it top.Replaced these gases leakages capacitors will get
    your TV power stable,and work again.Or tries websites like
    Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for
    the replacement.
  • SANYADE  OMOTOLA
    It will require a replacement of the high voltage flyback transformer and perhaps replacement of the horizontal output transistor - usually done at the same time. The cost will be over $150. If you really like the set it is worth it. If you were thinking about a new set with the advanced technology such as wide screen and hdtv reception, now would be a time to think about it.
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
Horizontal lines in laptop screen
Brand source customer service
Oct 02, 2017 | Computers & Internet
Dark shadow on left side of laptop screen
THE SCALAR OF YOUR LCD ARE LEAK IT'S RECOMEND TO REPLACE A NEW ONE LCD
Aug 18, 2009 | Computers & Internet
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
May 25, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Sony Bravia 42" Horizontal Lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Oct 19, 2017 | Sony Bravia KDL-42V4100 42 in. LCD TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
Horizontal lines on Screen
here's something you can try...remove the back and notice that there are ribbon cables (FRAGILE!) on the right and left side...alot of times these cables develope bad connections and cause the lines you see...other times the panel will be suspect. Removing these ribbon cables and reseating them have helped me determine in the past if it is a bad connection...or a bad panel
Jan 09, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
