Question about Canon PIXMA MP160 All-In-One InkJet Printer
My scanner has not worked since i purchased this printer. My error is as following: CANNOT CMMUNICATE W/SCANNER. cable may be disconected or scanner is turned off. CODE: 2,155,0. PLEASE HELP!!!!
    Problem Solver:
  • 10 Answers
Follow these steps:
1. Unplug the printer.
2. Uninstall the driver.
3. Re-boot your computer.
4. Then reinstall (from the CD if you still have it)
5. Follow install instructions with printer.
6. Test the printer/scanner/etc.
7. If this doesn't work... go to canon's website and download the most current driver for the printer. then redo these steps using the downloaded driver for step 4.
If this doesn't work, return the printer if you still can.
Posted on Apr 02, 2011
ON DISPLAY SCANNER ERROR
hello error is occured from your scanner unit.check scanner cable is working properly.if it is doesnt work,you have to replace scanner cable.
Jan 12, 2011 | Samsung SCX-4300 Monochrome Laser...
Canon MP 648 suddenly appeared a message: ERROR 5012, then after the power off and turned on again appears ERROR 5050. Printer error has occurred. TURN POWER OFF THEN BACK ON AGAIN. SEE IF THE PROBLEM...
From the service manual, both errors relate to the scanner unit:
[5012] An error occurred in the scanner FB motor.
(1) Cable connection (2) Part replacement: - Scanner unit
[5050] The AFE was faulty.
I don't know if the following YouTube video will help, but you could watch and see if it applies to your printer.
Error 5011 and 5012 Printer Canon MG 2570 MP 237 MP258
Feb 09, 2018 | Computers & Internet
My hp scanner not working saying cannot find pc but printer working fine
Hi
follow this steps
1.disconect usb cable
2.uninstall your printer from your pc
3.run setup from printers cd or from the driver you can
download from Hp official site
4.follow the setup steps
5.only connecte your printer to pc when setup ask you to do
If i helped you
pls vote me
Oct 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
SCANNER ERROR
Message comes with Printer Scanner Error 6
Turn Off Then on
Jul 21, 2010 | HP LaserJet 3055 All-In-One Printer
I epson stylus SX510W printer and I have an error message displayed that reads ''A scanner error has occurred. See your documentation'' The documentaion required me to switch the printer off and then on to...
hello there ill try to help you this seems to me to be a program error not the printer heres how to fix your problem my freind (hope this works it does 99% of the time) firstly disconect from the internet and disconect the printer now unistall the printer go to control panel and add or remove programs you should see it there and unistall if not go to printers and devices alsow in control pannel and remove it there now use the driver disk for the printer to install again ( dont conect the printer untill it tells you too) this should now have fixed it not got the driver disks? ok disconect the printer and go online to epson and enter the product then get the driver for your v.of windows download to desktop and then disconect the ethernet cable and follow the steps abuve just install from the desktop insteed of disk really hope this helps you if not let me know ill try a few other things
Apr 19, 2010 | Computers & Internet
Printer error code 6202 when I start my printer
I unplugged the power supply several times. So far it seems to be working.
Jan 15, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
Check Cables. Check Scanner Lock. Cycle Power.
the problem is the cable in the scanner's mainboard
Sep 15, 2008 | Office Equipment & Supplies
Error 21550 pixma mp160
Thsi usually happens with canon printers and scanners jsut re-install the driver...I wonder when they will fix it..This happens each time you disconnect the cable and then put it back..
Nov 13, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
165 people viewed this question
old marine
old marine
