Question about Baldor 7306d 7" Deluxe Grinder, 1,800 Rpm
Where are the brushes located on a Baldor 7306D grinder
  • 2,176 Answers
There are no brushes for this type of motor, it has centrifugal switches and starter windings/run windings.
Posted on Apr 02, 2011
What type and size capacitor goes on a Baldor 1/3 HP bench grinder
Much would depend on whether it is a start capacitor or a start/run capacitor.
If there is a switch on the end of the rotor operated by centrifugal weights it will be a start capacitor only but if there is no centrifugal switch the capacitor will need to do double-duty and the value could be critical.
Contacting a dealer or the manufacturer would be favourite but a motor specialist might be able to make a recommendation. Guessing isn't really an option and the working voltage of the capacitor is equally important. Most generic capacitors are rated in dc volts and for them to be safe used on ac mains the working voltage must be considerably higher than the rms value of the ac mains. It is best to use only capacitors rated for ac mains.
You will probably find the capacitor as a spare part from a dealer will be prohibitively expensive but once the value has been discovered and if possible the manufacturer, part number and so forth, great savings can be made by sourcing direct from the capacitor manufacturer.
I recently paid less than £5 plus carriage plus VAT for a capacitor the machine manufacturer wanted more then £60 for.
Nov 04, 2015 | Baldor Grinders
I have a Baldor 6in wheel grinder. Cat.No. 662R Ser w/10 94. A friend sent this to but the left inner casting was cracked and bent. Can I buy replacement? Part # G6FH3800 or 66FH3800. Thanks for any...
You can order it from this website
http://www.alexgs.com/product/baldor-electric-g6fh3800.html
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya
Aug 16, 2011 | Garden
I have a Baldor 1022W grinder but i'm not sure how it is wired. I've tried looking for wiring schematics but have been unsuccessful. All I need to know is how to tell if the grinder is wired 115V...
first off what does the plug look like? that would be one clue and also usually under the bottom plate there is a wiring breakdown. Let me know if you need more help
May 12, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
My grinder starts slowly and takes time to build up to speed. It is a model 612 and does not appear to be a capacitive start motor. All I can see under the base plate is a relay. Thanks for your...
Hi and welcome to FixYa, I am Kelly
Inside your grinder either the stationary switch or the rotating assembly that actuates the stationary switch has failed.
Download this pdf file:
http://www.baldor.com/pdf/literature/CA506_0806_WEB.pdf Then go to page 9
The rotating assembly is this part number: (most common failure)
34RS2060SP
You must remove the end plate / cap to change this part.
The statonary switch rarely fails unless the rotating assembly damaged the contacts when the rotating assemble failed. When the rotating assembly fails you often find a spring and flyweight loose inside the grinder during disassembly. Should your stationary switch have failed try and get a number off of it so you can get the right switch. Otherwise you have to use NEMA code / Body type numbers.
Thanks for choosing FixYa,
Kelly
May 06, 2011 | Baldor 612 6" Bench Grinder 3600 Rpm Stamp...
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone...
OC3012F12SPCYL OIL CAP 12MFD/370V
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
http://www.baldor.com/brands/baldor-dodge/contact-us/contact
https://www.baldorvip.com/servlet/productInfoPacket/1022W.pdf
Jun 15, 2017 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
Is the 612R made in USA? Is it all ball bearing?
Baldor has 26 plants in US, Canada, England, Mexico and China.The 612R is ball bearing, uses size 6203 bearings.
For more info go to www.baldor.com
Nov 01, 2010 | Baldor 612R 6 Inch Husky Grinder
How to wire a 3 phace 5 hp baldor motor
the neutral or white is not used. if the fourth wire is a ground then it goes to the motor frame. if it is a dual voltage motor then here is the wiring: for 240 volt 3 phase connect 4-5-6 together and tape, 3-9 goes on L1, 2-8 together goes on L2, 1-7 together goes on L3. To reverse direction swap any two line wires. For 480 volts 3 phase: L1 goes on T1, L2 goes on T2, L3 goes on T3. Connect together T6-T9 and tape, connect T5-T8 and tape, connect T4-T7 and tape. again to reverse direction swap two line wires.
Oct 14, 2009 | Baldor 115v,1ph, 3,600rpm 7" 1/2hpbnch...
What wheel do I use for grinding chrome
Grinding chrome is not recomended on a bench grinder
Aug 30, 2009 | Baldor Grinders
Unit has rt & lft threaded tapered (point) shafts & seems to have ability to ''chuck'' bits.---this is my first encounter w/ this system and to my dismay and chagrin i can't use it --have all specs...
Some grinders have tapered, threaded shafts that allow the use of soft buffing or metal polishing wheels, could that also apply to yours?
May 17, 2009 | Baldor Grinders
Baldor 7306d 7" Deluxe Grinder, 1,800 Rpm Logo
82 people viewed this question
Top Baldor Saws Experts
Tom Chichester
ray gallant
Are you a Baldor Saw Expert? Answer questions, earn points and help others
