Question about Refrigerators
Hi, We have a LG refrigerator model LFX 25970. We had a short power outage, power is restored now. After the power came back on, the ice dispenser started clicking and none of the display works, it clicks about once a second. We unplugged and plugged the fridge multiple times, it did not solve the problem. We also turned the ice machine off and on to no avail. When it is clicking, the water dispenser does not work. Any thoughts? Thanks, Patrick
3 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Refrigerator Ice maker stopped working after power outage
Check THIS out
Posted on Jul 26, 2009
Richie_asg1
  • 1036 Answers
SOURCE: Water is slowly trickling out of water dispenser
This is usually because the water filter on the supply line needs replacing.
If it has not been replaced within 6 months, then this will probably cure it.
Thank you for using Fixya,com
Posted on Aug 05, 2009
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
How do i fix LG refrigerator no power to ice and water dispenser and frezzor light is out
It sounds like you have a short in it somewhere, if it's under warranty then have it repaired, if not then take a volt meter and check to see where it's dropping power at.
Jan 08, 2015 | Refrigerators
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Compressor will not start on a frigidaire refridgerator
The compressor gets power from compressor capacitor or compressor relay.On some models there is capacitor and on some there is relay.May be that relay or capacitor got shorted causing the problem.
But if that checks out ok,then its faulty compressor causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Refrigerators
HI, I have a Whirlpool Side-By-Side Refrigerator model ED25PQXW01 and the ice maker isn't working, how do I fix it??
Hi
Check to see that the refrigerator has power and is working. Reset or replace the fuse or circuit breaker in the house if needed, especially if a power outage has recently occurred. Make sure the water valve is connected to the refrigerator and is fully turned on. Ensure that the ice maker is turned on. Some Whirlpool refrigerator models have a switch located above the ice bin; some models have an arm that should be raised up to turn the ice maker on. The arm is also located above the ice bin. Clear away any ice cubes that may have gotten jammed in the ice maker, bin or dispenser that may be preventing ice cubes from moving as expected in the system. Use a plastic utensil to clear away any obstructions. Contact an authorized service center for assistance if the above steps do not fix the issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LFX 25950SB, the Ice Maker is not working, just hear a click
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
klh
Feb 22, 2009 | LG LFX25960 Bottom Freezer French Door...
LFX 25950TT problem
Just had this same problem. We were away at Disney for four days - turned the icemaker off before we left. We have the LG french door double drawer freezer model. Came home, the ER IF code was displayed. Wouldn't dispense water or ice. Took the icebox out, and it was all frozen in the augers. Then I read on the door something to this effect - "if you turn off the icemaker, it will not continue to cool the ice. This will cause the ice to melt and leak out of the unit, and when it refreezes, the dispenser will not produce ice or water."
So, I took the ice box out, emptied it, reinstalled it, and the unit os making ice and dispensing water as I write.
Again, if you turn off the icemake, empty the ice box, or you will get the error message when you start the ice maker again.
Apr 08, 2008 | LG Refrigerators
Problem after power outage
yes it is but is a solder one and has to be open by a skill person to check for shorts most times the spike protector is short..good luck
Jul 27, 2006 | Maytag MSD2754G Side by Side Refrigerator
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
