Question about Air Tools & Compressors
My graco sprayer in leaking paint from around the piston rod. do i need to replace the seals or buy a new one. if i need to replace the seals how hard is it to do?
5 Suggested Answers
  • 98 Answers
SOURCE: need to repack pump on graco gm5000 gas paint sprayer
http://www.graco.com/
you can put your model in or if you have a part # you can enter it into one of the fields eventually you will fing a parts diagram for your unit.
Posted on Feb 21, 2010
digritz
  • 530 Answers
SOURCE: MY CAMPBELL HAUSFELD DH5300 PAINT SPRAYER WILL NOT SPRAY PAINT.
there are several issues that can cause this problem.
I will assume you have used the sprayer before so that will eliminate an incorrect air cap. The only other issues are paint viscosity, worn parts and the number one cause improper cleaning.
Be prepared for a complete disassemble of your gun. Depending on what you spray any residue can become hard as cement and it only takes a small amount to cause problems.
Below is a link to the manual that gives an exploded view of your gun.
Hope this helps but if not please let me know and I will trouble shoot further.
http://www.cpocampbellhausfeld.com/static/manual/www.cpocampbellhausfeld.com-dh5300.pdf
Posted on Jun 01, 2010
  • 760 Answers
SOURCE: paint sprayer won't pump
Ok, go to campbel hausfeld web site and download a manual for your sprayer : http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Find your model number and look at parts view. Pay paticular attention to the inlet and outet valves. They must be absolutely clean to function. These pumps must be thoroughly cleaned when finished.
Posted on Jul 25, 2010
  • 14 Answers
SOURCE: I bought a Graco Magnum LTS 17 paint sprayer but
You can find the manual here:
http://wwwd.graco.com/Distributors/DLibrary.nsf/Files/313036/$file/313036C.pdf
Michael
info@sprayfinishingstore.com
Posted on Jun 02, 2011
Hi my titan 400 its leaking from the oil cap area, I reduced pressure and still leaking?!
Hi Kamil,
Your Titan Advantage 400 needs to have its piston seals replaced which is why it is leaking into the oil cup. They are self-adjusting static packings. This is a classic airless wear situation; paint is abrasive. Its easy to do it yourself and if you do, you need to examine the piston; if it is worn or scored it must also be replaced otherwise it will wear out the new packings fast. All the parts to repack it can be purchased in a kit.
Jan 13, 2015 | Titan Advantage 400 Airless Paint Sprayer...
What type of oil does the 440 titan impact use
No oil! but you have to use throat seal at the pump piston
Jan 04, 2015 | Titan Airless Sprayer Owners-service-parts...
How to replace packing on a 5900 graco
There are two balls in your paint sprayer: One is in the piston and can be removed after you take the piston valve out to get the piston packings off. Be careful of the smooth surfaces of the piston where it contacts the packings. The other is in the intake valve (foot) and held in place by the ball guide or cage. The cage can get stuck because paint gets between it and the foot. DO NOT put something in the back of the foot and try to pound the ball and cage out. The cage is hard steel, read brittle and the tabs on the cage can/will break off. I usually clean out the foot as best I can then use needle nose pliers in the holes in the top of the cage and twist it back and forth until it gets free enough to come out. Clean all surfaces and it'll go in much easier than it came out.
Jan 20, 2013 | GRACO INC GMAX II 5900 Airless Paint...
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
NEED A MANUEL
The XR9 is a Graco paint sprayer so go to their home page at, http://www.graco.com/Internet/T_MainSite.nsf/Webpages/StartPage. Put your part number, 232740, in the 'Search Site' box on the left and the first PDF will be the manual for your sprayer. Graco manuals cover several model configurations so make sure you look for your part number's breakdown and information.
Mar 06, 2012 | Air Tools & Compressors
Air Tools & Compressors Logo
1,019 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
