Question about Canonical Ltd. Ubuntu
Ubuntu Command Box
I can't find the "run" box (command box) to run sudo?
    Novelist:
  • 202 Answers
Ou should be able to get the run box by pressing Alt+F2. If you are running Katapult press Alt+Space and then type the word. Or input the name of the program into the terminal...
if u get problem by this put the same question in goole website u get lot of answers
Posted on Aug 05, 2008
Installation of sqldeveloper on ubuntu 12.4
First, make sure you have JDK 7 installed. Then,
  1. Install alien with the command sudo apt-get install alien. This is used to convert RPM packages
  2. Download the Oracle SQL Developer package if you have not done so already.
  3. Run alien on the RPM package: alien -d package.rpm.
  4. Install the package with the command sudo dpkg -i package.deb. If there is a message saying there is a dependency problem while installing it, you can fix it by running sudo apt-get -f install.
Feb 25, 2014 | Canonical Ltd. Ubuntu
Installing Ubuntu Server on Dell Dimension 2400?
Step 1:
The Ubuntu Linux operating system is available either with or without a desktop environment. The version with the desktop environment is meant for personal use and includes word processing, email and graphic editing software. The version without the desktop environment is called "Ubuntu Server." The server version does not come with any graphical software or productivity software. There are three different desktop environments available for the Ubuntu operating system. The default is the Gnome desktop. The other two are the KDE and the XFCE desktop environments.
Log into the server. Type the command "sudo apt-get update" to update the list of software packages available. Type the command "sudo apt-get install ubuntu-desktop" to install the Gnome desktop. Type the command "sudo apt-get install xubuntu-desktop" to install the XFCE desktop. Type the command "sudo apt-get install kubuntu-desktop" to install the KDE desktop. Type the command "sudo reboot" to reboot the server. Ubuntu Linux Tutorials,Howtos,Tips & News http://www.ubuntugeek.com/install-gui-in-ubuntu-server.html
Mar 17, 2013 | Dell Dimension 2400 PC Desktop
HP Deskjet 1000 use with Linux operating systems
Question is old, but just in case:
installing HP printers in Ubuntu is very easy:
https://sites.google.com/site/tipsandtricksforubuntu/printer-info/hplip-driver
I am copying instructions here just in case site would go down:
  • open a terminal (Applications > Accessoiries > Terminal)
  • type the following command: sudo add-apt-repository ppa:hplip-isv/ppa
  • press Enter and if needed, type the required password
  • type the following command: sudo apt-get update
  • then type the following command: sudo apt-get install hplip
HPLIP is mentioned on official HP support pages as solution how to get HP printers working on linux.
Jan 19, 2012 | Office Equipment & Supplies
How to get su capability, just loaded ubuntu 10.10 want to remove avast application can't get permission to do so.
Start the package manager, search for the Avast program and uncheck the box to uninstall it.
If you need to run a root terminal the run the terminal, enter your password and type sudo -i at the command line>
Regards.
Dec 15, 2010 | Canonical Ltd. Ubuntu
I am trying to install a lexmark 6500 printer to software ubuntu and it continues to ask for a password to username root. I do not have a username to root. Help!!!
when you created your user account you temporarily have ROOT ACCESS.when you use the sudo command to run a install ( sudo apt-get install ) it asks for root password use your password
do a man sudo
it will explain what sudo is and does.
Oct 27, 2010 | Canonical Ltd. Ubuntu
Unlock CURRENT password on acer 250 netbook on ubuntu
Try these steps it worked for me it can work for you:
1. You’ll need to boot from your Ubuntu Live CD, choosing “Try Ubuntu without any change to your computer” from the boot menu.
2. Once the system boots, open up a new Terminal window from Applications \ Accessories and then type in the following command:
sudo fdisk -l (minus small leter L)
3. Now you’ll need to create a directory to mount the hard drive on. Since we’re actually booting off the live cd, the directory doesn’t really get created anywhere. then type
sudo mkdir /media/sda1
4.The next command will mount the hard drive in the /media/sda1 folder.
sudo mount /dev/sda1 /media/sda1
5. The command that actually does the trick is: chroot.
it is used to open up a shell with a different root directory than the current shell is using, and we’ll pass in the folder where we mounted the hard drive.
sudo chroot /media/sda1
6. Now you can be able to use the passwd command to change your user account’s password, and it will be applied to the hard drive since we are using chroot.
7. passwd 12345
Note: you’ll need to type your username after the passwd command in order to change the right password.
8. Now you should be able to reboot your system and log yourself in with your new password.
Sep 11, 2010 | Computers & Internet
Root Password
Hi Daniel,
Ubuntu has the root account locked by default. If you need to run as root, you use sudo username (This is recommended)
If you want to have a root shell on an Ubuntu system (It is not suggestedsuggested)
sudo -i
This is equivalent to the "su -" command sudo -s
This is equivalent to the "su" command
Jun 24, 2010 | Computers & Internet
How do i upgrade the OS of eee PC 900A to a netbook ubuntu 9.10?
download the image of ubuntu put it on a stick here you have two option uninstal the old OS or update if you want to update:
To upgrade from Ubuntu 9.04 on a desktop system, press Alt+F2 and type in "update-manager -d" (without the quotes) into the command box. Update Manager should open up and tell you: New distribution release '9.10' is available. Click Upgrade and follow the on-screen instructions.
To upgrade from Ubuntu 9.04 on a server system: install the update-manager-core package if it is not already installed; edit /etc/update-manager/release-upgrades and set Prompt=normal; launch the upgrade tool with the command sudo do-release-upgrade; and follow the on-screen instructions.more info on:http://www.ubuntu.com/testing/karmic/alpha1
Nov 23, 2009 | ASUS Eee Netbook
Ubuntu 8.04 Sound is Very Distorted HELP!!!
You need to add the following lines to /etc/apt/sources.list file or you need to make sure you have enabled Universe and multiverse repositories in /etc/apt/sources.list file
sudo gedit /etc/apt/sources.list
Make sure you have the following two lines save and exit your file
deb http://archive.ubuntu.com/ubuntu hardy universe multiverse
deb-src http://archive.ubuntu.com/ubuntu hardy universe multiverse
Now you need to run the following command to update the source list
sudo apt-get update
Install mplayer using the following command
sudo apt-get install mplayer
if you want to open mplayer just type
gmplayer
or
You can Open from Applications—>Sound&Video—> Mplayer Movie Player
Install libdvdcss2 and w32 video codecs in Ubuntu 8.04 (Hardy Heron)
Support for WMV, RealMedia and other formats has been bundled into the w32codecs package. This package is not available from the Ubuntu repositories due to licensing and legal restrictions.
For Ubuntu 8.04 (Hardy Heron) Users run the following command
sudo wget http://www.medibuntu.org/sources.list.d/hardy.list -O /etc/apt/sources.list.d/medibuntu.list
Then, add the GPG Key using the following commands
sudo apt-get update
sudo apt-get install medibuntu-keyring
sudo apt-get update
For i386 Users install Codecs using the following command
sudo apt-get install w32codecs libdvdcss2
For amd64 Users install Codecs using the following command
sudo apt-get install w64codecs libdvdcss2
Using above download locations you can install most of the mutimedia codecs for ubuntu.
Mplayer Plugin for Firefox
If you want to install Mplayer with plug-in for Mozilla Firefox run the following command
sudo apt-get install mozilla-mplayer
Apr 21, 2009 | Canonical Ltd. Ubuntu
Audacity sound ubuntu
Your command is slightly flawed. Try again as follows, making sure to include all spaces (copy and paste the command if it'll help)
sudo /etc/init.d/alsa-utils start
Note the space between sudo and /etc/blahblah and the space between /etc/blahblah and start. Also note the occlusion of the second L to the end of the alsa-utils command.
Hope this helps,
SlaeYer
Aug 03, 2008 | Canonical Ltd. Ubuntu
Canonical Ltd. Ubuntu Logo
107 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
Dennis Gutowski
Dennis Gutowski
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
