Question about Bbe Fjb 200x Phono Preamp
Just bought it today I grounded the tt to the preamp and have a hum coming thru my speakers
  • BBE Master
  • 5,603 Answers
First thing is to verify that ALL your interconnected equipment such as TT, preamp, Amplifiers ALL are powered from the same receptacle or power source. A ground loop might exist if they are on separate circuits in the room.
Second is the quality of cables must be good. Some have very poor shielding.
Posted on Apr 02, 2011
Get a hum out of the speakers with or without music
This s a ground issue or your driver board has a bad component on it which can be replaced with a new one if you can find it. Look for burn marks.
Nov 28, 2016 | The Music
Have Simmons SD9K drum kit. Started having a hum. Tried thru head phone or Mackie board. It still hums. Pulled each cable to drums or cymbals and it still hums. Anyone know what is causing this.
The hum is likely to be the sound of the ac mains electricity, either because the power supply smoothing has become ineffective in the amplifier or one or more of the audio peripherals or because the audio connections to the input of the amplifier have created a hum loop that is picking up the radiated energy from the mains supply and feeding it into the audio input.
Multiple grounding is often the reason for a hum loop. This is where an audio peripheral is not only grounded through the supply cable but is also grounded through the screened audio lead.
If the hum persists when there is no inputs connected the problem is almost certainly power supply related, otherwise it is likely to be a peripheral that has a faulty power supply or the culprit is a hum loop.
Hi-fi officianados have a number of tricks to deal with hum loops and google could lead you to these.
Grounding is an important safety consideration so appliances that are intended to be grounded must continue to be grounded but the loop could be broken by using special audio leads. The usual lead would use the screening as a conductor and so the screen must be connected both to the peripheral and to the amplifier.
A better lead uses an extra core conductor and the screen then becomes just a screen and is grounded only at the amplifier end and is not connected to the peripheral.
I hope this helps.
Sep 10, 2016 | Simmons SD9K Electronic Drum Set
Hum when volume at 0
with or with out a guitar plugged in
Mar 08, 2013 | Fender Hot Rod Deluxe Guitar Combo...
Mixing board hum
AC hum comes from poor grounding of components.
Jun 21, 2017 | Music
Where to buy TP4T pickup
You can try repair it. They are pretty basic. I would look for poor solder connections, and reflowing all solder joints in it would be prudent.
The hum is likely from a gain stage with a bad solder joint on the input isolation capacitor. Also check other wires and check for bad solder connections on the pickup connections as well. It can even pick up hum through a bad shieid/ground connection in the jack on the guitar
Mar 29, 2012 | Takamine 1 NEW Takamine EG350SC G-Series...
Hum on channel 2.
I assume that the hum exists without any cables plugged into the input. If that is not the case, then make sure all input cables and source are using BALANCED lines. If the hum is present with no input cables, since this is a tube type preamp, the input tube for the bad channel is first suspect. It is likely a 12AX7 or 12AT7 type tube. Since there are two channels, the first thing is to SWAP the two channels and see if the hum moves with the tube... if it does replace the tube. I have seen another problem with preamps in general where bypass capacitors from either side of the XLR connectors to ground get zapped with static and one side shorts. This reduces the gain by 6 DB and leads to hum.
Aug 30, 2011 | Behringer MIC2200 MIC.-PRE-AMPLIFIER
I have a Eupoport EPA 900 system. Recently I started getting a consistent, low pitch and fairly loud hum out of both speakers. The hum adjusts with the volume, and I have tested it with various working...
Is the hum there with NO input cables connected? If not, you have bad cabling. Make sure you use only XLR to XLR mic cables and not the junky ones with a 1/4 inch plug that are for Karaoke machines. These devices usually use switching power supplies and do not have the power supply originating hum of older equipment. If the volume control adjusts the hum, then the hum originates previous to the control which is either in the preamps or the external inputs.
Aug 25, 2011 | Behringer Europort EPA900 Ultra compact...
Just bought a ProFX8 mixer to connect to my Bose L1 PA system, but as soon as I connect the outputs to the Bose inputs and raise the master fader there is a "ground hum" even without anything...
Make sure you are using BALANCED audio interconnect cables AND that the speakers and the mixer are powered from the SAME receptacle... Yes, this means running extension cords. It is a ground loop problem. You should be using XLR or TRS cables BALANCED cables from the mixer to the basss unit of the L1 system. The bass unit and the mixer MUST be powered from the same receptacle to avoid ground loops and hum.
Aug 17, 2011 | Mackie ProFX8 Professional Compact Mixer
One of my Adam A5X speakers suddenly started making an annoying sound. it can be described as a hum in the middle freqquencies. I would guess it has something to do with the wiring? I will contact the...
Unplug the audio cable to it... IF hum persists, possibly a filter capacitor in the power supply has failed.. If it is quiet with no audio connected, look for bad cable or improper grounding such as running these from different receptacles in your facility.
Jun 23, 2011 | Adam Audio A5X Pair 2-way 5.5 inch...
Marshall VS65R is powered up it hums
Blown speaker NO (would not get sound at all)
Bad Reverb UNLIKELY (controls would deselect reverb and it would be out of circuit)
Bad preamp tube NO (controls have no effect)
Bad rectifier and/or filter caps LIKELY
Bad power amp POSSIBLE
Nov 29, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Bbe Fjb 200x Phono Preamp Logo
212 people viewed this question
Top BBE Music Experts
Michial Gueffroy
Are you a BBE Music Expert? Answer questions, earn points and help others
