I have a eziset 605 it will wash the clothes but when it comes to the spin cycle it wont spin but the agitator still turns causing the clothes to become tangled on one side causing to unbalance. i have tried to use the spin cycle without any clothes in it but it sounds like it is spinning but only the agitator is turning not the bowl. could you please help me thank you
  • 118 Answers
If you look you will find that when the machine is supposed to spin that is the spin bowl turn. Instead of the spin bowl turning, the agitator is turning and so BALLING the clothes. So......it is most likely a *** designed machine so it has a brake arm and pawl, operated by a small motor or a solenoid. This motor or solenoid is most likely not pulling the brake lever and releasing it to allow spin action. So check the release of the brake. Tony the technician down under....
Posted on Apr 02, 2011
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Hi i own a simpson eziset 605 washing machine. It is currently not spinning the clothes out. The belt is still on but not sure what is wrong with it. brigette
Brigette can you be more specific. Does the motor sound like it is still running? Or do you hear any uncommon noises ? Does it spin without clothes in the washer?
Dec 27, 2010 | Washing Machines
Hi I have a simpson eziset 605 washing machine and it has stopped spinning.. I have checked the belt and thats seems fine the washing machine just wont spin.. if anyone has any idea of what it could be...
Hi Carlee just read your posting.Now the Simpson Eziset machines come in top and front loader versions.Which type is yours?Please reply with this additional information and I will help you rectify this fault.
Oct 03, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Bad smell in Simpson Eziset 550
pour a few litres of vinegar in the machine on low level of water and do a wash with no clothes in it. should clean tub and drain hose
Sep 06, 2009 | Washing Machines
Agitator doesn't spin during wash cycle
If The washer won't agitate
Check to make sure no clothing got wrapped around the agitator. Check the lid switch, timer, and drive belt, other potential causes, such as a bad transmission or bad agitate/spin solenoid, but they are much more involved.
if the washer won't spin, the lid switch, timer, drive belt, transmission, or agitate/spin solenoid could be the cause here as well. Sometimes if the load is unbalanced or too heavy, the washer won't spin. Take some of the clothes out and try the spin cycle again with a lighter load.
Here are the steps to replace the agitator.
1: Take the fabric softener dispenser off and pry off the agitator lid.
2: Use a socket wrench with an extension bar to remove the stud and seal.
3: Remove the agitator top and bottom.
4: Check the agitator clutch assembly (located in the agitator top) for excessive wear.
5: To replace, just reverse the directions.
Jun 29, 2009 | Washing Machines
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
