Question about Quantaray QB-6550D for Canon SLR TTL Flash
My Quantaray QB-6500A flash will not come on. I have it attached to the Quantaray dedicated flash module. It used to work & now it does nothing.
3 Suggested Answers
maunderer
  • 5 Answers
SOURCE: Quantaray QDC-NK i TTL Digital Flash Module
The Quantaray Digital NK Module has a small tab on the side of the raised boss that the 8 pins sit on that prevents it from mounting on the QTB-9500A. It's intentional- the NK Digital Module is made for newer Quantaray flashes only. You'll need the older-style AF NK Module to attach to the QTB-9500A.
Posted on Aug 22, 2009
  • 11 Answers
SOURCE: Nikon D300 and Quantaray Flash...
I use their products and have had great success as well as great response. I don't have the Quantaray, but if you contact them they will most likely have a direct solution for that flash.
http://www.flashzebra.com/products.shtml
Posted on Apr 01, 2010
I have a quantaray qtb-7500a for an older n80 nikon but i want to use it with my d90 it has a af module nk
The QTB 7500A will work with the D90. However, you will not be able to use the iTTL mode of the D90. Use it exactly the same way you've been using it with the N80, letting the flash control the exposure.
May 10, 2011 | Quantaray QTB-7500 for Nikon TTL Flash
I have a quantaray qtb-7500a speedlight. It is for a Minolta camera. Is there any way to adapt it to fit Nikon equipment? jim
There are modules available to convert the camera into a Nikon lens. Right below your fill flash on the left hand side of the unit, there is a square button to release your current module and attach the new Nikon module.
May 20, 2010 | Quantaray QTB-7500 for Nikon TTL Flash
Mar 08, 2010 | Quantaray QDC-900WA for Nikon TTL Flash
Doesn't work with canon d40 digital camera
You may have identified your own problem.
Your camera is either a Nikon d40 or a Canon EOS 40d (aka Digital Rebel), there's no such thing as a Canon d40.
If your Quantaray flash has the wrong brand dedication module on the bottom for your brand then it won't work properly (if at all).
If this is not the cause, then please be more descriptive: does the flash power up at all, will it work with other cameras, do other external flashes work on your camera? You may just need to go into the menu and enable the hotshoe.
Click here as well if you lack an operation manual: Quantaray products are always a pain to find manuals for as they're badge-engineered models supplied in the USA by Ritz/Wolf. The trick is always to find what the individual product is usually sold as. In your case, it's a ProMaster FTD5700. Page 2 of the manual will help you to identify which dedicated module you need for this flash to work with your camera.
I hope that I've helped, if not then please report back with additional details, or if I've helped you to solve your problem then please take a moment to rate my answer.
Feb 14, 2010 | Quantaray QTB-9500A TTL Flash
How can I get the Quantaray QTB-9500A to work with the Canon rebel XT? It worked fine with my ellanIIE. Can I order a new module? Thank you for the help
You'll need the "AF module CN", but as the flash is no longer made will have trouble finding one.
It helps if you search for the correct flash model as Quantaray is a no-name bit of badge engineering for Ritz/Wolf.
Your flash is really a ProMaster FTD5700.
Please don't forget to rate my answer.
Sep 25, 2009 | Quantaray QTB-9500A TTL Flash
Quantaray QTB-9500A with Canon Xsi not working properly
This is probably way too late for the original asker, but the previous answer is incorrect.
The Quantaray QTB-9500A is in reality a ProMaster FTD-5700 and was designed for use with later model electronic 35mm AF models (using the correct dedication module).
As such, the trigger voltage is no higher than 5v making it safe for use on later digital SLR's.
The original answerer is clearly aware that high trigger voltages on flashes designed for earlier, mostly mechanical, 35mm film cameras are often harmful to later models, but you need not worry about your model.
Please take a moment to rate my answer.
Aug 30, 2009 | Quantaray QTB-9500A TTL Flash
I hav a Quantaray 9550 with a module to fit a Minolta Maxxum xtsi. Can it be used with a sony alpha?
Yes, it can, but you will likely loose some of features that make the 9550 such a nice flash.
Better bet, contact a dealer for Quantaray and buy the Alpha module.
Aug 22, 2009 | Cameras
Apr 06, 2009 | Quantaray QDC-NK i TTL Digital Flash...
Fuji s7000
Thanx to forum input I found a Quantaray qb-350a flash with a single contact on the hotshoe. By turning on "external flash" in the Fuji s7000 allows the Q350 to work beautifully and for about $40 bucks. It also works on earlier Fuji's like the 6200.
Thanx
Frank
Mar 20, 2009 | Quantaray QTB-9500A TTL Flash
Film camera flash(QB 6500A) with my new Canon EOS XT
Sometimes,I use one and tends to be ok under most conditions. Trial and error I am afraid on manual setting
Nov 20, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Quantaray QB-6550D for Canon SLR TTL Flash Logo
73 people viewed this question
Top Quantaray Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
teddyboy
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
