Question about Lorex L19WD843 19 inch LCD Observation System
My hard drive is not working - Lorex L19WD843 19 inch LCD Observation System
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
My old hard drive stoped working so I got a preowned one and now it is telling me it can't read the hard drive what do I do
The preowned hard drive maybe faulty.
To test this hard drive, connect this hard drive to an USB hard drive adapter then plug the USB hard drive adapter into the USB port of a working computer. If this computer can see the USB adapter and hard drive as an external storage device and you can view the folders and files on this hard drive the the hard drive is working, if not the the hard drive is faulty and you need a new hard drive.
Nov 10, 2012 | Dell Inspiron 9300 PC Notebook
My laptop does not pick up my hard drive
check ur hard drive cable is working . 2) install the cd that has come with ur hard drive and check it. ur hard drive may be of new usb drive check it it may work or ask ur shop keeper to exchange it....
May 17, 2012 | Transcend Storejet 500 Gb External Usb 20...
External drive is not recognized
Connect it to another computer to see if it works.
If it does not work reseat the hard drive connectors in the hard drive case to make sure the connections are secure.
If you cannot hear the hard drive spin when you connect the power then the hard drive maybe faulty.
Apr 13, 2012 | Buffalo Technology 320GB MINISTATION TURBO...
PXE - E63 error
This error is related to the hard drive.
It could be a faulty connection on the hard drive - try re-seating the hard drive.
The hard drive may be faulty - go into the BIOS and see if the BIOS detects the hard drive.
If the BIOS cannot detect the hard drive then the hard drive may be faulty ot the laptop's hard disk controller could be faulty.
To determine if the hard drive is faulty, remove the hard drive and connect it into an USB hard drive adapter and plug this adapter into a working compute's USB port. If this computer cannot see this hard drive as an external hard drive then this hard drive is faulty and needs to be replaced.
When the new hard drive is installed in the Compaq laptop, insert your Windows installation CD and install Windows, plus the Compaq's device drivers and your programs to get a working laptop again.
May 26, 2010 | Compaq Evo N610C Notebook
Hard drive is not working.
The clicking noise is most likely the hard drive trying to restart or start the drive i think the motor is not turning thus no data being sen nor received
Apr 13, 2010 | Iomega 750GB Esata/usb 2.0 750 GB Hard...
Disc drive stopped working
A hard drive can stop working just like any other electronic device when it becomes faulty.
First go into the BIOS configuration and check if the hard disk is detected. If not it could be faulty.
Next re-seat the hard drive, it just may need connecting again to make proper electrical connection.
If it still does not work, then remove the hard drive and plug it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external USB hard drive nor can you open the folders and files then the hard drive is definitely faulty.
To get the laptop functioning again, replace the hard drive, install Windows on the new hard drive together with the laptop's device drivers and your programs.
Dec 11, 2009 | Compaq Presario Notebook
Sony vaio
This fault is usually a disk controller problem/fault or the hard drive is not making proper connection or most likely the hard drive is faulty.
Try reseating the hard drive first.
If this doesn't work, check the BIOS to see if it detects the hard drive.
If the BIOS cannot detect the hard drive then remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external hard drive and cannot open the folders and files, then the hard drive is confirmed faulty.
Install a new hard drive and install Windows on this drive together with the device drivers and programs to get a working laptop again.
Sep 09, 2009 | Sony Computers & Internet
Its saying that there is no disc drive on my notebook and it has worked before, help me fix this!
You computer cannot find your hard disk. The hard drive could be faulty or the hard disk controller has failed.
Reseat the hard drive (remove it and install it again), this may fix your problem with the connector on the motherboard.
If reseating doesn't work, the hard drive may be faulty, remove the drive and insert it into a USB hard drive adapter and plug it into a working computer's USB port, if this computer see your hard disk as an external drive and you can see the contents of the hard drive then it is OK and the fault most likely is the controler in the laptop.
If you cannot see the hard drive then the hard drive is faulty. To get your laptop operational again, you need a new hard disk and need to install Windows on the new hard disk together with your programs etc.
Apr 27, 2009 | Acer Extensa 4620 Notebook
Disk management does not see working hard drive
Are the Hard drives setup as master & slave ? (plastic jumper on Hard drive at cable)..... is the Hard drives connected on separate ide cables... if they are ide drives ?
Mar 30, 2009 | Seagate Barracuda 7200.7 160 GB Hard Drive
Lorex L19WD843 19 inch LCD Observation System Logo
Top Lorex Home Security Experts
Lawrence Oravetz
gbob59
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
