F77 JRC TROUBLE
DEAR SIRS,
I FACE A PROBLEM WITH A F77 JRC. THE VOICES AND THE FAX DO NOT WORK . THE DATA WORKS FINE.ON THE DISPLAY THE STATUS IS "HOOK" ALL THE TIME.
I WOULD APPRECIATE YOUR PROMPT HELP ON THAT ISSUE.
BEST REGARDS,
PETROS MOSCHOPOULOS
OTESAT-MARITEL GREECE
TECH DEPARTMENT
SUPPORT@OTESAT-MARITEL.COM
00302104071112
SOURCE: New HL-5240 printer red status light upon powering up
My HL-5240 did the same thing, Here is what I found:
Look at the back of the printer. Pull down the back cover. Look to the right and the left of the exposed internals of the printer and there should be another handle/knob you can pull down. Pull these both down simultaneously and check to make sure there isn't a piece of paper in there! This was a shock to me! My office printer was held up for days until I found this hidden door in the back! I felt like an idiot that it was from a stupid paper jam!
Posted on Sep 05, 2008
rhoncruz
  • 134 Answers
SOURCE: Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Posted on Dec 01, 2008
  • 58 Answers
SOURCE: Fax Settings
Two items you need to do. Press user tools and go to fax settings from there you need to turn of auto fax reception and change to manual. (keep in mind, that when a fax comes in, meaning you pick up the phone and hear the fax tone, you will need to press the green start button to activate the fax sequence).
Also make sure you telephone is plugged into TEL and phone line into FAX/
www.mfpsolutions.blogspot.com
Posted on Jan 03, 2009
SOURCE: using a cable to my pc to transmit data my jrc showed error
Yes. There used top be a download at www.jrcamerica.com but I can't find it now. I bought the required null modem cable, used the intended J-NAV LINK 2300 softaware and still got the ERROR msg. If you figure it out let me know, because loading waypints/routes is very timely.
Posted on Jun 14, 2009
  • 40 Answers
SOURCE: C6180 FAX UNABLE TO SEND OR RECEIVE
check the the phone line, The fax sinal need good clear. Surely,plug the phone-line is rigth line socket. If you do that all, the broblem is still happenning,need to change "relay" on moderm fax board.
Posted on Jul 27, 2009
Tip
Apple Iphone Codes
*3001#12345# and tap Call. Enter field mode
Field mode reveals many of the inner settings of your iphone
specially up-to-date network and cell information
*#06# Displays IMEI. No need to tap call
IMEI is the unique identifier for your cell phone hardware
together with your SIM information it identifies you to the
provider network
*777# and tap Call. Account balance for prepaid iPhone
*225# and tap Call. Bill Balance. (Postpaid only)
*646# and tap Call. Check minutes. (Postpaid only)
These three are pretty self explanatory
*#21# and tap call. Setting interrogation for call forwards.
Discover the settings for your call forwarding. You'll see whether
you have voice, data, fax, sms, sync, async, packet access, and
pad access call forwarding enabled or disabled.
*#30# and tap Call. Calling line presentation check.
This displays whether you have enabled or disabled the presentation
of the calling line, presumably the number of the party placing the call.
*&76# and tap Call. Check whether the connected line presentation is enabled or not.
State whether the connected line presentation is enabled or disabled. Presumably similiar to the calling line presentation.
*#43# and tap Call. Determine if call waiting is enabled
Displays call waiting status for voice, data, fax, sms, sync data, async data,
packet access and pad access. Each item is either enabled or disabled.
*#61# and tap Call. Check the number for unanswered calls.
Sho the number for voice call forwarding when a call is answered. Also show
the options for data, fax, sms, sync, async, packet access and pad access
*#62# and tap Call. Check the number for call forwarding if no service is available.
Just like the previous, except for no-service rather than no-answer situations.
*#67# and tap Call. Check the number for call forwarding when the iPhone is busy.
And again, but for when the iPhone is busy.
*#33# and tap Call. Check for call control bars
on May 19, 2010 | Cell Phones
Tip
New secret of iphone
New secret
provider network
thank you
on Mar 19, 2010 | Cell Phones
Would like to know if this is a Voice/Data/Fax Modem?
This a voice/Data/Fax/ Modem. I was using it on windows xp, but does not seem to work on windows &
Jan 04, 2014 | Dell Bcm94154m Dell/inspiron 56k Mdc Modem...
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
DFM 562IS (DFM-562IS) Modem: SIR PLEASE SEND ME ITS ALL FEATURES.......
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
K56flex
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Computers & Internet
Installed voice over IP phone system today at work and now my winfax connects, sends page 1, but log status says "No acknowlegement received on last attempt" so it keeps retrying to send the fax. It worked...
Make sure your VoIP system has been adjusted for optimum fax transmission. VoIP doesn't do very well with fax, most providers much change the Codec to support fax (eg. t.38 )
http://www.getfaxing.com/winfax
Apr 28, 2010 | Symantec WinFax Pro for PC
My phone doesn't receive signal .on display it shows test mode.what is the problem?
is your phone line working perfectly?
You may also need to check if there is an option for changing the status of the machine from test to working status.
Mar 31, 2010 | Philips Magic5 Voice DECT Duo - Fax /...
I have a JRC NWZ4550 GPS. I've only used it once, I entered 3 way points and the system worked fine. Satellites lock on, all ok. I did a soft start, cleared the system, then started entering my way points....
If you are running a 4310 aerial with this unit the aerial ran out of date sometime in August 2008. You will have to buy a jrc 124 aerial. I had the same problem. Check with the agent TMQ International.You will find that the unit won't keep the date you have entered in it to set it up, it goes back to the year 1989 on the satellite page.
May 12, 2009 | JRC GPS
65 people viewed this question
 Grubhead
Grubhead
