Forget how to program my plug n power homebase cat, number 61-2470 that controls our outside lights
  • 436 Answers
Here link to all documentation:
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=61-2470&Name=Controllers and Remotes&Reuse=N
Good luck
Thanks
Please rate FIXYA
Posted on Apr 02, 2011
Saw jammed on wood and stopped. Will not run now. 110V model. How can I test to see if controller is blown?
Hi,there are electricle screwdriver on the market,(Homebase)
you can use this screwdriver to see ware the brake in the power is.
all you do is plug your saw in switch on hold one end of the screwdriver and just move the other end up the cable it will show a red light,if the light gose out then that is ware the brake in the power is so there will be your problem.
I hope this was some help.
this is a great tool that means you can find a falt without takeing every thing appart,its used for other things to which is great,worth a look.
Mar 20, 2015 | Makita 10" Dual Slide Compound Miter Saw...
Control panel not lighting up or responding. Curcut breaker is ok
Are you sure you have power to the outlet dishwasher plugs into?
probably under sink or behind dishwasher. if so, I'd check the plug and cord.
Mar 08, 2015 | Dishwashers
Why does my 98 dodge caravan have trouble climbing hills?
A transmission issue would give vibration tremendously during uphill. If you're not getting the vibration, or burning smell of transmission fluid, suspect clogged catalytic converters.
May 09, 2014 | 1998 Dodge Caravan
1998 dodge intrepid loss of power and chk eng light came on
Hi:Just one code there, or your descripotion is about two or mode fault codes; we will need exactly what code number is detected there.
You could find code description here: obd_codes.html
Hope this helps
Mar 05, 2012 | 1998 Dodge Intrepid
Loss of power.chek engine came on. did diag. test and said:heated cat.wec air sys. and acfridge
Hi there:Just one code there, or your descripotion is about two or mode fault codes; we will need exactly what code number is detected there.
Hope this helps.
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
    programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
    Oct 11, 2008 | Radio Shack (15-2147) Remote Control
    Malfunction heating pad
    Same F2, quick off problem here. Then I noticed that the gray plug on the power cord was not completely flush with the connector on the pad. I shoved them together until there is no gap. The unit's worked perfectly since then.
    Mar 24, 2008 | Sunbeam 805810 HeatSense Heating Pad...
    HOW TO PROGRAM RCA RCU310 Remote Control
    1. turn device on.
    2. hold code search untill light stays on
    3. press tv, vcr or whatever you want to program once. (light should still be on)
    4. press on and off button untill your device turns off.
    5. click enter on the remote. should be good,
    6, dont forget to go outside now and then,
    Mar 02, 2008 | RCA RCU310 Remote Control
    Computers & Internet Logo
    141 people viewed this question
    David Payne
    David Payne
