Question about Maytag Dryers
The element is getting too hot, and is blowing fuses. What could be the problem?
  • 126 Answers
Your thermostat has gone out in your dryer
Posted on Apr 02, 2011
Electric Water Heater blows fuse, but only every few years
Your residential water heater is not 9000 watts. Or it would blow the fuse every day and melt the wire. Instead, you have dual-element non-simultaneous 4500 watt water heater.
http://waterhatertimer.org/How-it-works.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Look at label for 'total connected watts'
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
25 amp breaker or fuse and 10 gauge wire is minimum acceptable for 4500 watt water heater.
http://waterheatertimer.org/Color-code-wire.html
Troubleshoot blowing breaker or fuse:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Why does it blow fuse once each year?? I don't know.
Fuses and breakers trip when overheating occurs on wire.
Each fuse or breaker is rated for heat, and over time, it will get hot and then cool and then get hot again ... this action weakens fuse or breaker.
To solve problem: install 3500 watt elements (and clean sediment out of tank). Wire will run cooler, and fuse will last longer. Whole fuse box will demand less power, and run cooler, and will last longer as a result. So there is less stress on electric service panel.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
3500 watt element will heat water to same temperature, but takes longer. For example: 4500 watt heats 21 gallons per hour, while 3500 watt heats 17 gallons per hour.
Apr 28, 2013 | Water Heaters
DLE330RAW amana dryer running too hot
The control thermostat on the blower housing is the one you need to change if it is getting too hot. It is taking too long to shut off the element. The only other thing it could be is a blocked vent making it overheat. The fuse is set for 350f the limit on the element is a 250 f one. I suspect the 250 f limit on the element is doing the drying not the control stat. Hence you getting overheat but not hot enough to blow the fuse.
Apr 13, 2013 | Amana DLE330RAW Electric Dryer
My dryer blew its fuse like 6 times, I would go to the garage and click it dryer fuses on and off and at first that worked but no it will run and stay on but just doesnt blow hot air
That sounds to me as if the heat element has broken and when it broke a small part of it fell onto the metal housing where the heat element fits into,as a result of the broke element no longer being suppost safe and sound it the housing but instead it sat on the housing and created a short circuit that caused the fuse to blow.
By replacing the heat element it should once again heat and not blow the fuse
GENE
Sep 18, 2011 | Dryers
I have a Bryant Heat pump installed 10 years ago. It keeps blowing a breaker(now a fuse) in the air handler. I have had a technician out here three times. He has replaced all four relays and checked for...
One of the heating elements is stretching enough when it gets really hot and it is touching a metal part somewhere which blows the fuse...
Pull the heating element part out and you should be able to see where it is arcing and causing the short...
heatman101
Feb 14, 2011 | Heating & Cooling
The dryer is not getting Hot ? blowing cold air
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Here is a video to walk you thru the troubleshooting process.
Jan 26, 2011 | GE DCVH515EFWW Electric Dryer
I THINK A FUSE BLOWED TO MY CIGARETT LIGHTER, FOUND A FUSE BOX UNDER THE HOOD THE FUSES ARE NOT MARKED
The lighter has an element that get hot to light the cigarette. That element acts like a fuse as well. It will show an open to the coil if shorted out. Alsao the case this element sets into has a built in fuse. If that fails, the lighter will not work. Ohm meters are used to check these items out if all fuses in the fuse box are OK fine
Nov 26, 2010 | 1999 Ford Contour
The dryer runs, but is not getting hot. Is there
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Nov 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer is not blowing hot air, checked heating element and coils are not getting hot
Check the thermal fuse. It is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. Test it for continuity with a multimeter. A lack of continuity indicates a blown thermal fuse. The heating element can be tested in the same manner. Hope this helped and best wishes.
Aug 06, 2009 | Dryers
Motor does not turn
if coils is heating are you sure motor isn't running or just the drum not turning ? if drum not turning suspect belt ..if motor not running but element still heating suspect element is contacting outer case ..with coil touching case 110 volts is present even without motor turning if timer is turned to heat position element will not heat to capacity but will get hot enough to eventually blow element fuse
Dec 19, 2008 | Dryers
Electric hob
You have a faulty heater element on the hob, what is probably happening is it is ok until it gets hot then it shorts and blows the fuse. You need to identify which hot ring is faulty by trying them in turn (if there is more than one that is) and then replace it.
Oct 21, 2008 | New World 60ESO Electric Kitchen Range
Dryers Logo
24 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
