Ok i need help lighting the pilot for the heater to come on and force air. Never had a trailor before. need help. can the heater work of of electricity also?
    Brigadier General:
  • 4,736 Answers
To answer your questions, it would help to know who the manufacturer of the heater is and the model number.
Posted on Apr 02, 2011
The WeatherKing Forced air heater stopped working in my house. The thermostat could turn it on in terms of sound but when I looked at the heater, all I saw is the pilot light. No air, hot or cold, was...
You will need to relite the pilot if this is a standing pilot furnace........If this has an electronic lite for the pilot then cycle power to the furnace and set thermostat to heat. and retry sequence. Once you get the pilot to lite then watch it to see if the main gas comes on. if it doesn't then you need to check and see if you are getting 24 volts to the gas valve with a volt meter. If you don't feel comfortable with doing this then you will have done everything that is simple. You will have to call a service tech. Problems that it could be are gas valve, limits not closed, ignition control board, main limit open because the blowor motor locked up or motor has open winding or run capacitor open.
Jan 02, 2011 | Weather King Heating & Cooling
Can we relight the pilot manually or do we need an electronic lighter? Ours appears to have gone out. Also please verify that what we're looking at IS the pilot light! Thank you!
if it is a permant pilot then you can light it manually , if is a hot surface ignitor then you will have to replace it , some electronic ignition has to be replaced , as it self lights .
Hope this helps you
Nov 30, 2010 | Coleman Propane Forced Air Heater...
Pilot light will light but when i release the pilot button it goes out
You will need to change the thermocouple. It is the copper probe that goes from gas valve to flame. Any good farm store should have one.
Jan 11, 2010 | Reddy Heater RLP100 Portable Forced Air...
Read the instructions on how to light the pilot but where I need to put the match I am not sure where to direct the flame to. I see the housing for the pilot but not where inside
You noted above it is a Coleman forced air Heater with a electronic ignition? You don't need a match to light the pilot, it lights automatic on a call for heat at the thermostat.If it does not light, then you have other problems. Let me know.
Good Luck,
Shastalaker7
Nov 04, 2009 | Coleman Propane Forced Air Heater...
How do i light a Reddy Heater rcp 2000 lp gas heater?
hold down the pilot valve knob and turn the arrow to pilot position push down on red button to allow gas thru pilot tube hold down and light keep button held down for 1-2 mins while pilot is on to heat up the thermocoulple then release and turn knob to on position.
Sep 12, 2009 | Reddy Heater RLP100 Portable Forced Air...
Pilot and Burner shut off at same time at various run times.
sounds like your pilot saftey is working.the pilot flame heats a device called a thermacoupler which gives a signal to the gas valve letting it know its ok to open main valve. you may need a new thermacouple , might have a dirty pilot orfice or a problem with gas pressure or worse case a cracked heat exchanger in any case in less you have some type of training you should call a pro
Feb 05, 2009 | Coleman Propane Forced Air Heater...
How do i install a thermal coupler for forced air heater gas
Thermo coupler is held in place with a clamp bracket at the pilot end and a small brass line nut on the other end going into the gas valve.The pilot flame must surround the sensing bu or wrap itself around it Press the pilot button for a few seconds and fire up the pilot flame. Wait a few more minutes and turn the gas vale on for the main burners. If it fires, your set.Good Luck,Ned
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
