Question about Toshiba 55H70 55" Rear Projection Television
2004 toshiba 65hx83 projection tv
No video but the sound and remote control functionality still works. i unplugged the set and waited 6 hours, then plugged it back in with no reset, picture is still black.
  • sikorajim Sep 06, 2008
    toshiba 55h70 sound works but no video with all inputs
  • hornva1 Sep 09, 2008
    no picture or sound just a hum
How do you know when your light bulb has burned out? I have sound with a black screen
Posted on Sep 18, 2008
Zenith factory reset
Hi Rebecca,
Specific reset instructions will vary depending on the model of your Zenith television. For many Zenith TVs you can reset to manufacturer defaults by pressing 'Menu' then press '9, 8, 7, 6, Enter.' If this doesn't work for your set, try a hard reset: unplug your television and leave it unplugged for at least 4 hours.
You can also try this:
Instructions
    • 1 Press the "Menu" button on your remote control. Use the up and down arrow buttons to highlight the video option. Press the arrow that points to the right to select the video option.
    • 2 Use the up and down arrow to highlight the video reset option. Push the right arrow button on the remote control to select video reset.
    • 3 Press the right arrow button on the remote control to return the video to original values.
Read more: http://www.ehow.com/how_8528201_do-reset-zenith-tv.html#ixzz316gKG3ra
May 08, 2014 | RCA 50in Tv M50 Wh 92s Dlp Hdtv Works But...
MY TOSHIBA 65HX83 remote will not operate the TV
You may need to get a universal remote and the programming codes in order to operate everything you'd like to on your tv. I'm guessing the remote you have is newer than the TV?
"Toshiba 65HX81 65 in. Rear Projection Television...65HX83 remote "
Sep 24, 2012 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65HX83 television will play DVDs but has no sound. Help!!
If you are using an S-Video, you will have to hook up the RCA jacks for sound.
sawrepairman
Jul 23, 2010 | Toshiba 65HX83 65" Rear Projection...
Hi, tv set goes into standby,when you reset the picture is bright green for about 10 seconds and goes back into standby.
tv is drawing too much current and protection circuit kicks on and shuts tv down. try turning all screen controls all the way down. if that doesnt fix it, sounds like bad green picture tube. suggest local service center
Nov 09, 2009 | Toshiba 65HX83 65" Rear Projection...
Bright green picture
defective green picture tube crt. suggest local service center
I have Toshiba 65HX83. and having problem with remote control. Change new battery but seem to doesn't work. only with on/off butten works. But I think on/off butten itself having problem, because doesn't...
Lol?Anywho it could be that.What it is though is far from sticky.Buttons have pressure "receptors" on them that pick up pressure.Otherwise the wires might have been frayed or come undone in the remote control.In that case contact a proffesional or buy a new remote.Hope it helped
Oct 08, 2009 | Toshiba 65HX83 65" Rear Projection...
All buttons control tv/video, remote stopped working
Unplugged it for an hour.... buttons changed.....Unplugged it for four hours and everything worked......Left it plugged in overnight and back to original problem....
Oct 02, 2009 | Toshiba 32A33 32" TV
Exactly same problem just happened today! Only power button on the TV set and remote control works, no sound
I had this problem happen to me today. What i did was unplug the tv for an hour and when i plugged it back in, the first time setup appeared on the tv. The remote and the tv buttons worked fine after that. Hopefully that works for you too.
Jun 06, 2009 | Panasonic PT-52LCX66 Projection Television
SHARP T.V. not responding to remote, but remote isn't broken
Here are the Toshiba codes for universal remote- 000,048,049,072,073,105,109,118,160,162,190,&241 try these codes and see if this works.ThankYou for using FixYa and Have a Nice day.
Feb 05, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba TV 35A44 Volume Issue
I had the same problem, you'll probably find that that particular button will push further into the set then the others, this is due to the a weakening of a cheesy metal guide which directs the projection off the back of the button into the corresponding microswitch. This metal guide will bend and will push against the switch.My solution, (and it ain't pretty) was to unplug the set, remove the button( I used a dremel cutting bit), locate the guide,a small metal plate with a hole in it. Bend the plate toward the front of the set then tape over the hole. I haven't had the problem since.You WILL have to use your remote for further functionality of the volume, However all of the buttons seem to be inherantly poorly designed and will weaken over time, AVOID USING THEM!
Aug 23, 2007 | Toshiba 35A44 35" TV
Toshiba 55H70 55" Rear Projection Television Logo
181 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
