Question about Honeywell Heating & Cooling
Need to replace batteries - cannot get unit open to install new ones.
  • 2 more comments
  • lmcwhir225 Apr 02, 2011
    Thank you for responding, Roger. I am widowed and have no one to help with this problem. I have been in this house for 14 years - it was here when I moved in. It is a Honeywell Chromotherm III. The only numbers I find on it are 97-3663 - hope this helps. I have taken pictures, but not sure how to add them here. I'll try sending them by replying to the email.
    I tried sending pictures through email, but don't believe they went through. Please let me know how I can do this. Thank you.
  • lmcwhir225 Apr 04, 2011
    Hi Roger - thank you for hanging in there for me. I finally was able to loosen the screws and jiggle the thing off the wall. Replaced the batteries and think it is working well now. Thanks again.
    One more thing, Roger - I do not have a manual on this thermostat. Do you know if there is one available online or perhaps where I could order one. That probably would have helped me with my dilemna. Thanks.
    Scholar:
  • 133 Answers
Thermostats almost always snap onto their sub base. Look closely around the stat. You will see the prongs that secure it. Be gentle.
Posted on Apr 02, 2011
  • 3 more comments
    Cannot find any prongs...
  • Roger Jelinek Apr 02, 2011
    I'm sorry that did not help. Can you tell me what Brand and type of thermostat it is? A picture would really help. Is it a newly installed unit? Please give me all you can for info.. We will get this done. Model number too. If need be, I will look it up for you. Thank you for your patience!
    Roger
    Hello again. I am sorry for my delay in response. I have a few medical problems and was laying down. I sincerely apologize for not being more thorough with my answer. Most just pull off but some have screws. Try looking in the lower 2 corners under the flip down cover. There should be 1 screw on each side. Loosen them counter clockwise. The bottom should then be free to pull out, lifting it slightly will remove it. You get 30 to 40 seconds to replace the 3 AA battery's before it will lose its program and you will need to reset your times of operation. Please let me know how you are doing again,OK?
    Roger
  • Roger Jelinek Apr 03, 2011
    Just checking to make sure you are OK. feel free to write any time.
    Roger
  • Roger Jelinek Apr 04, 2011
    I'm happy to help. I am new on the site and found I enjoy helping. Please write anytime you have a problem. Thanks for grading me too. It helped me improve.
    Roger
How do I change the battery on lift master pro
You can purchase a replacement battery assembly from Amazon.com for $69 (I just replaced mine). If your battery backup is mounted on top of your opener, you simply unplug the backup white plug from the back lower right corner of the opener. There are two screws holding the battery pack to the opener, one on each side which need to be removed with a Phillips screwdriver and saved to install the new battery pack. Then simply lift off the old back up power suppl (careful, it's about 8+ lbs) and install the new one, being careful to install the screws snugly and plug in the new backup. (Ceiling mounting is simply unplugging the backup unit and removing the two mounting screws from the ceiling; then reversing for the new unit) The green light will start flashing rapidly showing its charging and will do so for several days. Then it will turn solid green showing a full charge and you are set for years of backup readiness. Some words of caution: Some places sell only the replacement batteries. They do NOT have the same connections as the original batteries. So unless you are willing to purchase crimp-on connectors and do your own wiring, don't waste your money. Plus, if the electronic circuitry is bad and not just the batteries, you will waste money and time. My suggestion is buy the EverCharge as a unit and save the headaches. I did.
Apr 18, 2014 | liftmaster 485LM EverCharge Battery Backup
Have several Tripp Lite Omniplus 1000LCD UPS battery backups that are no longer working. They are several years old. I assume that these units need new batteries. Where do I get battery replacements,...
A little research on the internet will answer your questions about battery replacements and cost. There are numerous sites selling batteries for your particular unit. Do a Google search on the battery type and see what you get. EBay is another possible source for batteries once you determine which size and what ratings you need for your replacements. The best way of determining how to replace the batteries is to open the UPS's case and carefully record how you remove the old batteries and then install the new ones in reverse order. You will have to open the UPS up to get at the batteries to determine type and specs so removal and re-installation should be easy from there.
Apr 30, 2011 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
The internal battery is dead. How do I replace the the old battery with a new one. Please explain how to open the battery compartment and how to install a new lithium-ion battery.
The internal battery, that only Garmin can change. It would cost $125 just to send the unit in if it needed work outside of the warranty period.....hopefully the battery will last about five years.If you get it replaced from Garmin. If still you want to void the warranty and get it opened then there is step by step images shown how to open the unit.But that actually damages the unit. Click this link directly:--- There are total 26 images showing step by step procedure.Click on each image and continue disassembly. http://content.techrepublic.com.com/2346-22_11-178052-6.html?tag=content;leftCol ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Garmin StreetPilot C330 GPS Receiver
I have a GE 7-Day in-wall Programmable Digital Timer Model # 15086 which I installed about a year ago and was working fine until a few days ago. The screen went blank and the unit does not work. It acts...
The battery is not easily replaceable. It's a 1.2 volt, 80ma Nickel-metal hydride battery, that is soldered to the circuit board. I opened the back of the switch to find the battery. The one in this switch was in bad shape. It looks like the battery broke apart, but wasn't leaking. The switch is less then a year old. Bad design.
I just opened this up today and am going to look for a replacement battery. But soldering will obviously be involved to get the a new battery back in place.
Jul 30, 2010 | GE Hardware & Accessories
New battery
there is a great video on you tube showing how to install a battery in the h320. do a search on you tube for h320 battery install
May 30, 2010 | iRiver H320 MP3 Player
Instrument panel lights will not work after new battery was installed. Previously, When door was opened one could hear static noise and flickering of instrument panel lights. Battery was checked and was no...
Hi 1987 Honda Civic lihgts on instrument panel. New Battery. and replaced blower unit but lights on panel not working. I am yet to install stereo unit which was taken out by previous owner - very roughly ! Wondering if not having stereo will effect instrument panel lights. Cheers Steve
Nov 22, 2009 | Chevrolet Impala Cars & Trucks
B/D CM600 LAWN MOWER. INSTALL NEW BATTERY. HOW DO I REMOVE AND REPLACE THE COVER? THERE ARE TWO CLIPS ON THE FRONT END. DO I NEED A SPECIAL TOOL TO OPEN THEM?
The site that you need for the repair manual is Dewaltservicenet.com and in the middle of the page towards the bottom type in your model number to get to the page with a parts explosion. I briefly looked at it and it appears that there are 2 bolts on the back of the cover and then you would lift the back and slide the 2 flats on the front out to remove it. Also a concern is that about a 1/3 of these parts are no longer available. If you need any more help let me know and have a good day.
Jun 20, 2009 | Sport & Outdoor - Others
H10 20gb needs new battery
try visiting this website for directions to take your unit apart.
h10
cheapest option is to buy a certain torx screwdriver and plastic tools to open player up, replace battery from a cheap as-is player from ebay.
Mar 31, 2009 | iRiver H10 MP3 Player
Camera will not retain time setting
Firts check the state of the litium battery, this is locate near the Audio/video port in your camera, with small flat screw driver you will be able to remove it. If the same situation occur after replacing the litium battery and i'm assuming the unit had never be open before unfortunately your camera needs new main board ass'y. But if the case is that some one open the unit before check for a loose conector from the litium unit to the main board.
Aug 20, 2007 | Canon PowerShot A520 Digital Camera
Heating & Cooling Logo
265 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
