Question about Ruud Central System Air Conditioner
Not sure what type of thermostat to hook up to run it
    Genius:
  • Ruud Master
  • 1,033 Answers
Hello, most programmable thermostats will work with your unit. Honeywell and white rodgers makes good quality thermostats. Here is a link to some thermostats....http://yourhome.honeywell.com/home/Products/Thermostats/
Posted on Apr 02, 2011
Atwood furnace rv
try to jump the r and w where the t- stat wires are maybe bad t-stat
Jul 04, 2013 | Heating & Cooling
I am trying to wire a typical programable thermostat to a split type air conditioner.... the air condiontioner is a Coolmart 2 ton (24k btu) split type
Hello, you need to run 2 wires, one from the y terminal and the other from the c terminal on the control board in the Furnace to the outside unit contactor. At the contactor just hook up each wire to one side of it. At the thermostat you need to hook up a wire to the Y termimal.
May 15, 2012 | Heating & Cooling
I have a Trane heat pump, model #TWP060C300A and a Trane air handler, model #TWE065E130A. Heat pump is 5.0 ton, split system. Air handler has a variable speed motor and a 20Kw 3-phase auxiliary heat strip....
Honeywell Chronotherm thermostats have always had a great reputation for longevity and reliability. They are also much more user-friendly than the other types of programmable thermostats out there. Make sure you get one that states 2-stage heat, heat pump. T8611G will offer that for you. There are many out there that claim to be suitable for heat pumps; however, they do not have the ability to utilize your auxiliary heat strips (2nd stage of heat).
Before you attempt to replace, be sure to write the wire colors and their corresponding terminal marking on a sheet of paper........of your old thermostat. This is very important to make it easier to hook up the new thermostat. Also, before you disconnect the wires, be sure to shut off the circuit breaker to your air handling unit. You can ensure you have the right one by putting the fan switch in "ON". When you turn off the right breaker, the fan will stop running. :-)
I hope you find this information to be very helpful to you. Please don't forget to leave a rating.
May 09, 2010 | Honeywell Programmable Thermostat Heater
Just installed a honeywell thermostat (CT87N) fan runs but compresssor does not
Make sure you have the green thermostat wire hooked to the G terminal. You can also place a jumper between R and G to see if the fan will come on once the green wire is connected.
May 02, 2010 | Heating & Cooling
Our fan for the intertherm p3ra-024k will not shut off. We have put new wiring from thermostat to unit. He pulled the green wire like the serviceman told him to when he serviced it and it still keeps...
You have a problem with the wiring somewhere it could be in the thermostat. When the service man said pull the green wire off that was the power to the fan. The thermostat should wire up as red to the R terminal on the thermostat this is the 24 volt feed to your thermostat and to the unit. The white wire should hook up to the W terminal on thermostat. This white wire is to the heating section of your furnance it activates the heat mode. The yellow wire hooks up to the Y terminal on the thermostat this is the outside condensing unit control for the a/c. The green wire should hook up to the G terminal on the thermostat this is your fan wire that activates the blower in your furnance If this wiring isn't hooked up as such then your problem is in the wiring from thermostat to units inside and out. Also if you have changed the thermostat you need to be aware of the setting for the thermostat and the type unit you have. Most thermostats are universal however, you need to make sure that on the thermostat the setting for heat pump on the thermostat it will have a small switch and on switch will have hp at the top and nonhp at the bottom. If you have a heat pump you need to make sure that the setting on the thermostat is on hp if not a heat pump nonhp is the setting. Also there will be a switch that has g at the top and e at the bottom This is you gas or electric heating seletor switch make sure this switch is in the proper position for either gas or electric heat. Good luck on your repairs Hope this helped
Dave
Nov 02, 2009 | Intertherm P3RA-024K Air Conditioner
Programmable T stat
your trane heat pump energizes the reversing valve with O - orange y - is to turn on the unit make sure you have your orange wire hooked up and the tstat programming set to heatpump otherwise your reversing valve might be bad
Jun 30, 2009 | Honeywell Electronic Programmable...
I have a Honeywell T8000C1002 thermostat I got from my inlaws and it doesn't have the owners manual. I'm trying to hook it up to where an old rocker murcery honeywell was at and can't figure out how to...
Your red wire from the old R terminal goes to both the R and Rc terminal on the new stat. Other wires from old stat move to same terminal on new stat. You will not have any connections to the B or O terminal. Sounds like you probably already have it hooked up right though. This thermostat is what we call a power-stealing thermostat. It "steals" is power by running a trickle current to the transformer from the R terminal back through the W terminal. This meathod requires a standard resistive type thermal relay for the heating system. If you have an electronic type circuit board, many times they do not provide the proper type of connection for the thermostat to "steal" the necessary amount of power to run on. This is solved by installing a resistor from W to C in the furnace. If you have a standard electric furnace with thermal relays, then the problem is most likly the thermostat
Jun 22, 2008 | Honeywell Heating & Cooling
Refrigerator Keeps running
Replacing the thermostat should correct the problem. Be sure to install the thermstat exactly as the one you are removing, assuming it hasn't been changed prior. Hope this helps
Jun 10, 2008 | Beverage-Air Beverage Air KR48-IAS 44.9...
Carrier XHD183D Through-the-Wall Heater/AC runs constantly
YOU COULD EITHER HAVE A THERMOSTAT PROBLEM OR FAN CONTROL PROBLEM.TURN THE POWER OFF AT THE FURNACE AND TAKE THE THERMOSTAT OFF THE WALL.MAKE SURE YOU MARK THE WIRES SO YOU KNOW HOW TO HOOK IT BACK UP AGAIN.RESTORE POWER TO THE FURNACE.TOUCH THE WIRES THAT WERE HOOKED TO THE R & G TERMINALS ON THE T-STAT TOGETHER AND HOLD THEM THERE.OBSERVE THE OPERATION. WHEN YOU TAKE THEM APART DOES THE BLOWER STOP?TRY IT A FEW TIMES. IF IT CONTINUES TO START AND STOP YOU GOT A BAD T-STAT.JEFF
Dec 13, 2007 | Carrier XHD183D Air Conditioner
Ruud Central System Air Conditioner Logo
112 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
