Question about Epic View 550 Treadmill
I see an oil stain on the floor under the left front of my treadmill. (21" from the front and 9" from the left side). What is the cause of this and what can I do to fix it ? Thank you. Yves F.
  • 4 more comments
  • yfontaine918 Apr 03, 2011
    I don`t know what to tell you. I`m the orginal owner of the treadmill and never oiled or greased it.
    YF
    about 4" dia.
    OK Thanks
  • yfontaine918 Apr 05, 2011
    Sorry for my late reply, I purchased my treadmill at Costco approx 12 years ago.
    I haven't used it much until about 3 years ago when we started using it (3 hours/week).
    As you probably can tell I`m not to familiar with FixYa. Every time I look all I saw was your message telling me you would be back in 30mins. It was only this morning I saw the view more comments button.
    Even if it`s still not clear why the oil/grease spill was 4" to 5" in dia. I will give you 95% rating for you time, effort and patience. Thank you.
    YF
  • yfontaine918 Apr 06, 2011
    yes, thank you.
    YF
  • 274 Answers
HI there! Treadmills dont actually have any mechanical parts that store any type of oil. There are packs of bearing in the system that use a grease pack but grease has such i high viscosity that it wont flow from the unit. Oil in fluid form is actually only used to lubricate the belt on the treadmill. Are you the second owner? If so maybe the previous owner had over oiled the belt causing it to leak on your floor. I hope that this helps shed some light on your question. Post any other questions you may have if you need more help.
Posted on Apr 02, 2011
  • 7 more comments
  • Kelly Comstock
    Kelly Comstock Apr 03, 2011
    Are you there? Let me know if this helps. Your question keeps popping up on my que. If this helps please give thumbs up :)
  • Kelly Comstock
    Im sorry to say but the oil wouldn't have originated from the treadmill since the only oil base lubricants are the oil on the belt and the grease on the bearings. How large is the stain? I will check one more thing that could be the possible source.
  • Kelly Comstock
    Ok, I will be back in about 30 minutes
  • Kelly Comstock
    Oh one quick question, How long have you owned this treadmill?
  • Kelly Comstock
    The oil may be from the factory oiling the belt.
  • Kelly Comstock
    If you are satisfied with the help I have provided would you be willing to accept the solution? If so i make $2 :) thank you
  • Kelly Comstock
    Kelly Comstock Apr 05, 2011
    Could you please rate the comment. I would really appreciate it.
  • Kelly Comstock
    Yeah i didnt notice the comments tab for 4 days. :) thank you!
  • Kelly Comstock
    Have you marked the question as solved or helpful? It is still showing in my que as unsolved.
I have to lower the front crossmember to remove the oil pan. Is there any precautions I should know about? It is on 2004 jeep liberty 4x4
no engine stated, they even have diesel. or 3.7L GAS.
I toss my first coil, land on 3.7L V6.
great question, like the very first ever.
most just do it and get in trouble. vast posts in this.
but whats up, what is wrong, what part failed.?
this is best to know, so we can send you the official chapter on this from jeep.
sure use jackstands, never jacks only and never bricks .
04,KJ jeep 4wd pan off.
in chapter 9 ,under diagnostics, and pan leaks. that?
it says read
Refer to 9 -
ENGINE/LUBRICATION/OIL PAN -
REMOVAL). page 1555 (3.7L)
and i quote:
REMOVAL
1. Disconnect and isolate negative battery cable.
2. Install engine support fixture.
3. Raise and support vehicle.
4. Remove front wheel assemblies.
5. Remove skid plate (if equipped). (Refer to 13 -
FRAME & BUMPERS/FRAME/FRONT SKID
PLATE - REMOVAL)
6. Drain engine oil.
7. Mark adjustment cam position of front lower control
arm bolts.
8. Remove front lower control arm bolts. (Refer to 2 -
SUSPENSION/FRONT/LOWER CONTROL ARM -
REMOVAL)
9. Disconnect LH tie rod. (Refer to 19 - STEERING/
LINKAGE/TIE ROD END - REMOVAL)
10. Disconnect LH lower ball joint (Refer to 2 - SUSPENSION/
FRONT/LOWER BALL JOINT -
REMOVAL)
11. Disconnect LH strut clevis (Refer to 2 - SUSPENSION/
FRONT/CLEVIS BRACKET - REMOVAL)
12. Remove LH front axle (Refer to 3 - DIFFERENTIAL
& DRIVELINE/HALF SHAFT - REMOVAL)
13. Remove front axle brace bolts.
14. Remove front prop shaft. (Refer to 3 - DIFFERENTIAL
& DRIVELINE/PROPELLER SHAFT/
PROPELLER SHAFT - REMOVAL)
15. Drain front axle.
16. Using a transmission jack, support front axle.
17. Remove axle bracket bolts. (Refer to 3 - DIFFERENTIAL & DRIVELINE/FRONT AXLE - REMOVAL)
18. With RH axle still in place, remove front differential.
19. Remove transmission oil cooler line bracket.
20. Remove engine to transmission stiffening bracket.
21. Position Special Tool 8534 on fender lip and align the slots in the brackets with the fender mounting holes.
22. Secure brackets to the fender using four M6 X 1.0 X 25 MM flanged cap screws.
23. Tighten the thumbscrews to secure the sleeves to the support tube.
24. Secure the support tube in an upright position.
25. Assemble the flat washer, thrust bearing, hook and T handle.
26. Using the M10 X 1.75 mm flanged nut supplied with the support fixture, secure the chain to the front engine
lifting stud.
27. Loosen engine mounts.
28. Remove oil pan bolts.
29. Seperate oil pan (1) from engine.
30. Move oil pan to one side, remove oils sump bolt and windage tray bolts,
NOTE: Do not pry on oil pan or oil pan gasket. Gasket is integral to engine windage tray and does not come
out with oil pan.
end quote, (off)
Nov 30, 2016 | 2004 Jeep Liberty
Reebok v8.9 treadmill
you must LUBE the deck belt INMEDIATELY, however this indication is the lack of maintenance, probably your have a worn deck, see the diagram attached, and take action.
God bless you
Jul 22, 2012 | Reebok Exercise & Fitness
A friend recently gave me a ProForm 700 treadmill that folds up & the front left side of what appears to be the belt or possibly the rotor sounds like dolphins talking when you turn it on. How can I...
dEAR Sir:
I will help you inmediately.
HOW TO LEVEL THE ELLIPTICAL CROSSTRAINER:
After the elliptical
crosstrainer has
been moved to
the location
where it will be
used, make sure
that the ends of
both stabilizers
are touching the
floor. If the elliptical
crosstrainer
rocks slightly during use, turn one or both of the leveling
feet under the front stabilizer until the rocking
motion is eliminated.
2) You must put a little oil ( tree in one oil) +a little grease in the rotor shaft.
Hoping that you fix this, anyway if you need some extra help, contact me.sincerely.
blessing.
E.CUADRA
Managua, Nicaragua C.A.
Sep 13, 2011 | Proform CrossWalk TreadSoft Treadmill
Loose belt
tighten the back bolts to check tension lift the sides of the w/belt in the middle . sides should be 2-3 inches high
Feb 28, 2011 | Precor 9.21 Treadmill
When I run on my 620 it feels like it slips and I almost fall, like I'm running in my socks on a tile floor. This just started happening and now I can't use it at all, is there something I can tighten?
You mean front- to-back or side- to-side?
If its side to side, adjust the allen bolts at the bottom front of the treadmill. If its front to back, and your treadmill is at least a few years old, the belt is probably stretched and needs replacing. You can get a quote for a new belt at http://www.treadmill-world.com/parts-manuals.html
Dec 20, 2010 | Proform XP Weight Loss 620 Treadmill
How to get rid of diesel oil stain on concrete floor? Last week, a leakage happened from the nozzle of the diesel tank after some sloppy maintenance works on the nozzle. The diesel dripped onto the...
If detergent and scrubbing is not working try a solvent ... but if that does work directly on the stain go the next step and create a poultice by saturating an absorptive material (such as kitty litter or sawdust) with a strong solvent (acetone, xylene, lacquer thinner, or MEK) and then smearing the material over the stain. Cover the poultice with plastic, and let the process of osmosis take over. The solvent will break down the oil, and the absorptive material will suck it out of the concrete. Part of the challenge with oil related stains in concrete is that the material has migrated below the surface into the concrete. The poultice process does takes time and may not be cost-effective or practical for removing large stains.
Jan 14, 2018 | Plumbing
Describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
May 31, 2010 | Proform Exercise & Fitness
Ironman Triad motor cover will not come off
To remove the motor cover (#19 from parts list), you have to remove the follow items first:
- Left and right fenders (#20 and #21 from parts list)
- Left and right sideboard covers (#49 and #50 from parts list)
There are 4 screws holding the cover - 2 at the front and 1 on each side. Be careful when you lift the cover, the circuit breaker cable is attached to the cover.
Finally, you may want to reconsider doing that. There is nothing under the cover that requires maintenance. The big *** motor is driving the front tread roller through a belt. The roller has sealed bearings that do not require oil.
Feb 19, 2010 | Ironman Exercise & Fitness
Cant find oil filter on my 89 s10 blazer?
I have an 89 s10 blazer with the 4.3 tbi. the oil filter is a remote oil filter. there are two hoses running from the engine to the filter, which is located in the engine compartment in front of the left front wheel. it's mounted to the side.
Jan 15, 2009 | 1989 Chevrolet S-10 Blazer
Epic View 550 Treadmill Logo
189 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
