I just moved and had someone disconnect my high end surround sound home audio system. I'm still trying 2 figure out the connections to the back of the speakers.. They are B & W Nautilus SCM1 loudspeakers, just need to find a diagram or picture of the wires that are needed and how to connect them.... I cant find the instruction booklets...
    Problem Solver:
  • 10 Answers
If your speakers looks similar to these...
You should see 4 connections on each speaker.
Look for a label that says "IN" or "INPUT"... probably the top connections. 1 is gold (with a red cap) and one is silver (might have a black cap on it). If you have the original cables, they will be red and black.
Attach the red cable to the gold... black cable to the silver. Do the same on the back of your audio system (more than likely red/black look for the "OUT" or "OUTPUT" connectors.)
The main thing is making sure the cables are connected to "like" colors (when possible).
The other two connectors on each speaker, if labeled "OUT" or "OUTPUT"... are for piggybacking more speakers. Otherwise, they are more than likely used as a "RETURN".
Posted on Apr 02, 2011
My Vizio gallevia 1080 progressive liquid crystal hdtv has no sound-see details for question/detail..
Here are the most common reasons you may not have sound.
Starting with the most common solutions for no sound from TV:
Television Has No Sound Answer 1: Make sure TV is not muted.
Television Has No Sound Answer 2: Make sure the TV is not set to SAP (secondary audio protocol)
Television Has No Sound Answer 3: Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)
Television Has No Sound Answer 4: Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.
Television Has No Sound Answer 5: Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)
Television Has No Sound Answer 6: If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.
Television Has No Sound Answer 7: Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.
Sep 28, 2016 | Shopnbc VIZIO Gallevia 42" 1080p LCD HDTV
Tip
How to make a connection to an iPod and Sony SS2300
<p>The SS2300 is a Sony digital surround sound system with a Blu-ray player. This gives you the ability to play high-definition video, while experiencing the content in full surround sound audio. However, the speaker system audio inputs, so you can connect external devices, including Apple iPods. Although no direct connection to iPod, you can use a single cable to the signal from the iPod surround sound system. <br /> <p><br /> <p>1. Insert the end of 3.5 mm to 3.5 mm to RCA splitter in the headphone port on top of Apple's iPod. <br /> <p><br /> <p>2. Connect the RCA cables into one of the "Audio In" ports on the back of the Sony SS2300. Multiple connections exist and you better take note of the connection you use. This makes it easier later on if the connection to the iPod. <br /> <p><br /> <p>3. Power on the Apple iPod and Sony SS2300 receiver. Press the "Input" and select the connection to the iPod is connected. <br /> <p><br /> <p>4. Press the "Play" button on the iPod and play audio content through the Sony surround sound system. <br />
on Aug 09, 2011 | Apple iPod touch
How do i hookup my magnavox mrd 210 to my lcd tv for surround sound. have tried to connect with rca wires in back of tv to surround sound system and nothing. tried side of tv and nothing. my surround sound...
Have you seen the user guide?
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000036122.pdf
The TV is intended to be an end point of the video, not a source of audio. Many TV's (monitors) don't have ANY audio, much less surround sound capability. Composite Video is theminimalist video connection for setup; Component video to the TV should suffice for viewing DVD's.
Is your TV the SOURCE of surround sound programming (via an antenna) or does the programming come from elsewhere like a Cable Box? THAT would be the source you need to tap for surround sound.
Aug 23, 2011 | Philips Magnavox MRD210 System
We are trying to hook up our 65" Mitsubishi DLP TV to our JVC surround sound...basically we can get the DVD to work with surround sound but when we have the tv on our sound doesn't come out of our...
That cable doesn't exist. You can't just shoot electrons into one end of a copper cable and have light come out the other end.
My $.02...
Treat your TV like the primary user of the Hi-Def Video ONLY, not the source of any audio. Ask yourself, does it really NEED to be in an audio chain if it doesn't tune the station off the air?
Your JVC should be the primary destination of high-end audio, directly from, say, the Cable Box' while the Hi-Def video is sent to the TV.
Zigzagging good audio and video through the room to devices that don't need it is expensive and wasteful, plus it adds complexity and unnecessary connections that add nothing but could fail.
Feb 15, 2011 | JVC THD-50 System
I have a Polk home surround sound system problem
Need to know the model no of the Polk sound system to assist.
Jun 21, 2009 | Polk Audio SurroundBar Center Speaker
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
Help With My Rear Speakers
Just clicked on sound effect on the lg tv remote it was set to 2.1 changed to 5.1 and the system came alive!!
Oct 07, 2008 | LG LHT854 Theater System
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Sound Problems with HD TV
get the digital audio optical cable and connect the to the tv- got it working tonight
Oct 07, 2007 | Samsung HT-Q100 System
26 people viewed this question
 Grubhead
Grubhead
