Question about LG Dryers
I have an lg dlgx0002tm gas dryer and the power turns on but I can't get it to start. The start button just flashes and it won't start after I select a cycle... I did manage to get it started twice...but i don't know how I did it...please help
  • Anonymous Apr 02, 2011
    The power is fine..how do I Check the thermostat? I read that it could be the door switch..is this possible?
  • 4,323 Answers
Hi
Please unplug the dryer and check for any loose connections or loose power cord. If connections seems to be fine then try using the dryer with a different power socket. If it still doesn't work then it is due to a faulty thermostat and you would need to check these thermostat's, if necessary replace them. You can buy the parts from this link---
LG DLGX0002TM dryer Parts
Hope this helps... Please post back if you need more information.
Daniel
Posted on Apr 02, 2011
  • Daniel Scott
    Daniel Scott Apr 02, 2011
    You can take ohmmeter and check continuity for the thermostat....Use your ohmmeter to test your switch for continuity. Begin by
    setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a
    two-wire switch, touch each tester probe to each of the switch's terminals. You
    should receive a reading of infinity. While the probes are still touching the
    switch's terminals, press in on and hold the switch. The reading should change
    to zero. If the test you conduct does not produce these results, you should
    replace the switch. Hope this helps...please post back for further assistance.
    Daniel
    Daniel
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
The dryer won't turn on when plugged in. However, when I open the door, the drum light turns on.
I have the same dryer and the same problem...I have power to the unit but it wont turn on....the light in the door is on....there is a small cllick to the top left when I try and start it..thats it..!!...did you get a solution yet?..thanks..mike
May 15, 2011 | LG DLGX7188 Gas Dryer
Whirlpool Dryer 3.5 years old has power but will not turn on. Not a breaker problem. has electricity. Drum turns by hand. No noise is heard.
we had a very similar problem on our DLE3777W LG clothes dryer. It would power up normally, all drying options and speed and heat selections behaved normally but when you tried to start the dryer the start button and the time remaining indicator would flash until the unit was turned off. Called LG and Best Buy and they could only tell us to contact a repair shop. But I realized that the light was burned out inside, so I replaced it myself to avoid being charged by the technician I was about to call. The burned out light bulb WAS the problem, as soon as it was replaced the dryer worked perfectly. I think I saved a couple of hundred dollars with a $4 light bulb. I would have been mad to have the technician show up and charge me $120 just to show up, then an hourly rate and then the bulb.
Jun 26, 2010 | Whirlpool WED5800S Electric Dryer
Dryer will not start
EJ
Jun 07, 2010 | LG DLE7177 Dryer
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 11, 2010 | LG DLG5932W Gas Dryer
Dryer won't power up, says check filter
Check the door switch first.Than look for possible thermal fuse has cut off.
May 22, 2008 | LG DLE2514 Electric Dryer
Dryer shuts off on own lights blink
Turn off breaker wait an hour turn back on.
Apr 03, 2008 | LG DLE2514 Electric Dryer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
