Question about Napoleon Prestige I P600RB Propane Grill
Ignition button does not work, need to light manual on Napoleon P600RB, and the grill uses a lot more gas than our previous Weber
    Brigadier General:
  • 4,736 Answers
The push button peizo ignitor may simply have lost it's ground. Trace the wiring fro the push button igniter to peizo spark ignitor(s) at the burner(s). The wire simply slides onto a needle like pin, on the bottom of the peizo. Gingerly, pull the wire off and then slide it back on. This should reestablish the ground. Also check the spark ignitors to make sure they're not covered with grease. If they are, clean them with a cotton ball soaked in alcohol.
As far as gas consumption is concerned, some gills do use more than others to reach sear temperatures. Usually, because of their burner design or configuration. However, once you preheat your grill to he temperature you want, that doesn't mean the flame height has to remain the same all the time. Once you start cooking, there's no reason you can't turn the burner(s) down some and conserve fuel.
Hope this helped you and Happy Grilling.
Posted on Apr 02, 2011
I am looking for an owner's manual for a Napoleon Prestige 1 natural gas barbecue. Also, could you please tell me what purpose is served by the middle of the three knobs that control the gas flow....
Peter, the center control knob of the cluster of 3 in the middle of the control panel, is for the rear rotisserie burner.
To help you further, I have included a link to your discontinued model, that you can download and print for future reference. It covers both Propane & Natural Gas Models.
http://www.napoleongrills.com/Care/manuals/PT600RBI.pdf
I hope this helped you and Happy Grilling!!
Jun 29, 2011 | Napoleon Prestige I P600RB Propane Grill
The igniter box inside the grill is rusting and disintegrating. I bought the Weber igniter kit at Home Depot, but it has a red push-button, and I can't see how to begin replacing the igniter under ...
I have provided 2 links for you. One is the Assembly Manual for the Genesis B 330
and the other is the Owners Manual. Both should prove invaluable to you, in replacing the Ignitor Button. You can download and print each manual for future reference.
Assembly Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/AssemblyInstructions/Genesis_310320330_LPng_AssemblyInstrctns_56507_022811.pdf
Owner's Manual
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20ES%20Series%202007newer/OwnersGuides/Genesis_320330_LP_OwnersGuide_56508_111010.pdf
Hope this is some help to you. Please let me know. Thanks & Happy Grilling!!
Jun 17, 2011 | Weber Genesis Silver B Grill
Need a lid pivot
try google the bbq or the bbq centre in calgary
Jun 28, 2010 | Napoleon Prestige I P600RB Propane Grill
Our igniter doesn't work.
clean the elctordes on the burners make sure the battery conections are clean corrosion free
Jun 21, 2010 | Weber Genesis E-310 Gas Grill
Igniter Stopped working
Igniter could be shot. Take out igniter and put near something metal. Push button to see if sparks occur. If not igniter is no good. If this works, the end of wire that is near wear the igniter sparks to light grill could be to far away from metal, bend to get closer to metal, so it will spark, or end could be covered with grease, clean end and try for spark again.
Jun 14, 2009 | Weber Performer Grill
Second burner will not ignite on Weber grill
Its probably an obstruction in the burner. Take both the burners off and clean them inside and out with a brass brush. You need to clean them both, since the second burner is dependent on the first working properly.
Step by step procedures are in your manual. Go to http://weber.com/help/manuals.aspx to download it.
Jun 03, 2009 | Weber 1851001 Gas Grill
Weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
May 26, 2009 | Weber Q Grill
Weber Summit Grill Igniters
I contacted Weber and they sent me a complete igniter system. I will have to install it.
Oct 06, 2008 | Weber Genesis Gold B Grill
Napoleon Prestige I P600RB Propane Grill Logo
431 people viewed this question
Top Napoleon Grilling Experts
paulcarew
Lawrence Oravetz
Pierre Legault
Are you a Napoleon Grilling Expert? Answer questions, earn points and help others
