Question about Franklin FWC36 Wine Cooler
Both sides of the wine cooler started warming, not cooling. One side was 95F, and the other 87F at the time we discovered the problem. Any hints?
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
How do I know whether a thermoelectric cooling system is better for me than a compressor?
This depends on several factors: how much wine you keep on hand, where you will be putting the cooler (cool/warm room in the house) and if you are buying a freestanding cooler/built-in. If you never have more than two cases, plan on keeping the cooler somewhere it won't get too warm and you want a freestanding cooler, you should look into purchasing a thermoelectric cooling system.
Jul 31, 2012 | Furniture
I have a marvel wine cooler that frosts up and also tends to have temperture issues. Bottles on second shelf freeze. Temp adjustments to less cold make it too warm.
you have a restriction in the cooling side sounds like the filter line dryer is clogged up and will need to be replaced. Also the system will have to be recharged by a professional check to see if its in warranty.
Dec 17, 2010 | Marvel 6BAR Wine Cooler
Hot on the sides and in the back in the bottom,
Your coils are built into sides and top of cooler. Allowing unit to cool, by disipating heat.
Oct 15, 2010 | Danby DWC283BLS Wine Cooler
Stopped cooling compressor warm to touch
Feel the condenser on the side to if its warm top to bottom. If It's warm good if it's cool bad it's out of gas. That means leak in the system. If there is a leak, a new box may be cheaper than to fix it. If it is warm check the evaporator and evaporator fan. Make sure the fan is working and the evap-coil is not frozen.
I hope this helps.
Aug 23, 2010 | Haier BC112G Wine Cooler
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
Franklin FWC36 Wine Cooler Logo
26 people viewed this question
Top Franklin Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Franklin Refrigerator Expert? Answer questions, earn points and help others
