Question about Canon Pixma Pro 9000 MARK II InkJet Photo Printer
Print head is clogged will not free up pixma pro 9000 mk ll Any Suggestions?
5 Suggested Answers
tenorsax
SOURCE: Print head remains clogged canon pixma iP 4000
I have successfully managed to clean the print head with isopropyl alcohol by placing a flexible plastic tube over the cartridge seat, filling the tube partially with the alcohol, then blowing very hard through the tube. The alcohol does not appear to harm anything.
Posted on Aug 17, 2008
  • 739 Answers
SOURCE: I have a Cannon Pixma Pro 9000 Printer. I can't seem to get vibr
This is the third time in 4 days I've answered a question like this.
If you are serious about printing your photographs (and I guess you are -seeing the printer you have bought) then your printer and your monitor have to be profiled. But it's not quite as simple as that - the printer profile will vary as you use different types of paper and different makes of paper as they react differently with the ink that is laid down. So, for example, say you are using Canon FA-PM1 paper, you will need to use one printer profile and then you switch a PermaJet Hi Gloss paper you will need to switch to another profile.
Check out some photo mags as there are often adverts for companies who will do the profiles for you - basically it will cost you one way or another.
Posted on Aug 08, 2009
pineworks
  • 4041 Answers
SOURCE: I'm trying to remove the print head on Prima Pro
Hi there
I have one like this, it will come out just lift the lever and just pull outby tilting it a little from the to side, after you taken it out gave it a good clean with some white sprites with some small brush, gave it a shake dry and wipe it dry, try not to touch the head it selfe.
All the best Pineworks
Posted on Mar 04, 2010
walesarumi
  • 6993 Answers
SOURCE: I have canon pixma proi 9000 I keep getting an
Hello
Follow the below steps in order to clear the error:
1.With printer OFF press and hold resume
2.while holding it down push and hold Power button
3.Release resume whilst still holding down power, the light should be green (not flashing)
4.Push resume once (orange) twice (Green)and a third time (orange)
5.release power button.
6.Then power it off and on again after it's finished making any noises and settled down.
Good luck.
Posted on Aug 12, 2010
Canon pixma MarkII pro 9000 has an error 5C00 or purge error?
That is probably some paper or a foreign object inside the machine. Check around the waste station and at the far end of the printhead travel in both directions. Remove any found foreign objects and restart the printer. If there is nothing there to find - it is probable that the is a mis-alignment of the gear train that selects the various functions of cleaning, paper feed, and waste purging. In that case, there is not a lot you can do short of a complete strip down and rebuild with no guarantee of succes.
Jan 30, 2014 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Ink smear on back of print job canon pro 9000
control panel - printers- highlight printer but dont select - top right printer preferences - maintance- clean printer heads etc clean with all options available. should fix the problem.
Feb 10, 2013 | Canon PIXMA Pro9000 Printer
My Canon Pro9000 MarkII prints photos with a red tint
You probably haven't calibrated your monitor to show the correct colours, so in whatever photo programme you're using, you're setting the red tones too high. Test this by first not calibrating your monitor, but turning down all the red tone until it looks washed out. Print this and see if it's better. If so, set your monitor to a cooler colour temperature. If the result is no better, check your print dialogue settings to make sure you are using an appropriate colour profile. And, for example, if you're using Photoshop, tick 'let Photoshop manage colours' in the advanced profile settings box. Hope this helps. I doubt there's anything wrong with the printer.
Dec 29, 2012 | Canon Pixma Pro 9000 MARK II InkJet Photo...
Canon pro 9000 printer -green tint on all prints
theres an option in the printer options. if you have run the clean printer head option then you may need a new printer head
May 03, 2012 | Canon Pixma Pro 9000 Mark Ii Inkjet Photo...
Hi there
Mar 04, 2010 | Canon PIXMA Pro9000 InkJet Photo Printer
I have replaced both the colour and black ink cartridges in my Canon Pixma IP 200 printer, but now it won't print anything. I have tried the computers cleaning programs but that has not worked. Any...
The print head is clogged.Try to unclogging manualy.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0054.
Nov 05, 2009 | Canon PIXMA iP2000 InkJet Printer
some your print head bloked cos of dry ink. just takeoff print head try soak with warm water few minute. carefull not hole print head only to remove dry ink that all
Aug 08, 2009 | Canon Office Equipment & Supplies
Installed new print head, all inks are ok but still wont print
Usually when that happens on the Pro 9000, the purge assembly is not cleaning and priming the printhead properly. A new purge assembly runs around $29.95. Part number
QM2-2973-000.
Jun 23, 2009 | Canon PIXMA Pro9000 Printer
Pixma Pro 9000 Canon Printer is printing terribly colored photos.
HOW LONG HAS YOUR INK SAT IN THE PRINTER WITH OUT USE AND IS IT A CHEAP INK THAT YOUR USEING ? IF SO THAT COULD BE THE PROBLEM
Apr 05, 2009 | Canon PIXMA Pro9000 InkJet Photo Printer
Document print quality
A solid line sounds like a jet (in the print head) always on. Replace the print head (<$50 on eBay).
A white line (no ink) sounds like a clogged print head or a burned out jet. Replacing the print head will fix either one. If it is clogged, you might be able to clean it but this procedure is complex (soaking or special cleaners). Read about cleaning in other posts.
Jul 30, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Canon Pixma Pro 9000 MARK II InkJet Photo Printer Logo
74 people viewed this question
old marine
old marine
