Question about Samsung SMH9187ST Microwave Oven
Peeping , screen says 5E - Samsung SMH9187ST Microwave Oven
  • 2,382 Answers
Hi, SE stands for "sensor error". It means that your humidity sensor has shorted and unfortunately needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave.
It must be replaced, there is no way to clean it. The part itself is usually about $30 so depending on the cost of your microwave it may or may not be worth it.
Posted on Apr 02, 2011
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
Jan 27, 2016 | Samsung SMH8165B Microwave Oven
Maytag Microwave MMV4203DB00 HAS A 5E CODE AND IS NOT WORKING AT ALL WHAT CAN I DO?
Hai,you unplugg it for few seconds and reconnect if doesnt clear its a pc board problem which will need atechinician
Sep 12, 2014 | Microwave Ovens
Microwave started beeping with nothing in it now it says SE or 5E
These issues are usally due to a defective touchpad or control board. Troubleshooting would require disconnecting the touchpad ribbon cable from the control board to see if that made the problem go away.
Jul 17, 2014 | Microwave Ovens
5E display on maytag microwave
<- Let me know your full model number from the tag on your oven so I can give you detailed information repair.
Unless there is grease or moisture on your control circuit board, "SE" means you have a shorting membrane keypad.
Jan 05, 2014 | Maytag MMV1153A Microwave Oven
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Mar 20, 2012 | Samsung Microwave Ovens
Recently purchased this microwave (4-5 months ago) 5E error light comes on. Unplugged worked for short period - lights came on and off, things started beeping and the 5E came back on. Have repeated this...
"SE" means you have a shorted membrane keypad. It's not uncommon for it to be intermittent or partially operable.
Since it's under warranty, I would contact Samsung for a free fix. See your owner's manual.
Jul 06, 2011 | Samsung SMH9151ST Stainless Steel 1000...
Displaying 5E on the screen
"SE error" on a Samsung microwave means you have a shorted membrane keypad.
You can check here to see if your model may have been involved in a recall to fix a defective keypad, etc.
Apr 24, 2011 | Samsung Microwave Ovens
Maytag microwave that has a code of 5E or SE. The
I have the same problem. Did you get an answer? Thanks. l issa
Jun 08, 2010 | Maytag MMV4203D Microwave Oven
Morning Peeps A hole has blown on the inside screen of the door can I replace the door or screen Thanks
you can but use caution because if it is fitted wrong it can leak radio waves
Apr 27, 2010 | Microwave Ovens
Panasonic NN-H503B. Now some years old. Switched it on at the plug this morning and it did the following: constant peep, peep, peep, accompanied by the display flashing 9/Beef 10/Pork, 9/Beef 10/Pork...
It sounds like you have a shorted pad ("defrost", maybe?) on the keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Dec 12, 2008 | Microwave Ovens
Samsung SMH9187ST Microwave Oven Logo
318 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
